after searching for install on a weber I cant go to any links inside a message for this board....links to other sites work fine.
http://www.tercel4wd.com/forums/viewtop ... f=7&t=2954
http://www.tercel4wd.com/forums/viewtop ... f=7&t=5856
http://www.tercel4wd.com/forums/viewtop ... hilit=hood
http://www.tercel4wd.com/forums/viewtop ... f=7&t=6009
http://www.tercel4wd.com/forums/viewtop ... f=8&t=5807
http://www.tercel4wd.com/forums/viewtop ... ine#p33319
http://www.tercel4wd.com/forums/viewtop ... non#p33524
they all say "whoops! Bad filename there buddy! Better head back from where ya came! Go Back"
nothing works...ive tried logging out and logging back in but nothing. is there something wrong with the board or me?
just found something out...if I go to a link and it says "whoops! Bad filename there buddy! Better head back from where ya came! Go Back" I can go to the address bar and delete the word "forums/" and it works. Is anyone else having the same problems....
example: go to this page https://tercel4wd.com/forums/viewtopic.php? ... l&start=15 and the first message from ARCHINSTL has a link in it if i try to go there it comes back with "whoops! Bad filename there buddy! Better head back from where ya came! Go Back" if you take out the word "forums/" and refresh the page it works.
whats up with links
Re: whats up with links
yeah, it's because chad (the guy who manages the forum) had to switch servers or something. you figured it out, just remove "forums/" from the URL.
- Neu
dlb wrote:yeah, it's because chad (the guy who manages the forum) had to switch servers or something. you figured it out, just remove "forums/" from the URL.
What dlb said.
I'd have to manually go back and change EVERY link, which I can't do.
I can change the 404(Error) page to give some more info, which I'll do, but beyond that it's just removing /forums/ from the URL, which isn't difficult.
