so im starting a new project
shogun
Re: so im starting a new project
Post by shogun »
im still waiting on my friend for the crank, if he doesnt come through i´m knife edging one stock one and send it to be balanced
teaser of todays work
shogun
Post by shogun »
3ascv head you can se the actuator in the back and the valves in front of the springs
here you kinda see the valve in the intake port
now lets get into buissness
side by side 3ac and 4ag
inner workings
the difference between the pumps
a little bit of porting, just to get better flow of oil
the exit to the block, it had a sharp turn so i radiused it and made the change a lot smoother
shogun
Post by shogun »
well i have a little update not much but its a begining, and Carlos(tercel4wdrules) youll be getting a present soon
i did the begining of the machining in the lathe and started to do some modeling
here is the begining of the machining program, font was killing me so had to change it twice!
after a little convincing mastercam said ok and gave me this simulation
halfway through the drilling process
the begining of the lettering
finally the machining is done just the keyway is missing but that is just a half hour job
still looking for pistons and trying to decide if i knife edge the crank
shogun
Post by shogun »
ohh btw the stock pulley weighs 1489 grams, this one has 304 and i still can machine off like 5 mm off and the keyway, so im confident it could go mid 200 grams, since its for the street im not taking any more weight, the one i use for racing is underdrive and weighs close to 100 grams
intense!
WOW - Pretty!
shogun
Post by shogun »
quick update, started using my sandblaster and did my valve cover, vht wrinke black its the wavy cover for the 3asu head im puting in
