custum exhaust
- My tercel:: No tercel. (stolen)
custum exhaust
Hi everyone i was wouldering if anyony has done a totaly custum exhaust for these cars?
Im going to start making one for my car. so the plans for the exhaust ar to remove the cat, muffler and go strate from the exhaust maniflud down a little to a y and take the two pipes on eather side of the drive shaft and come out on both sides befor the back tires i will have pics to show you where it is hopefully going to go soon.
Re: custum exhaust
No mufflers? That will be neat for several minutes.
Re: custum exhaust
ya i hope to have no mufflers but if i need them i will get some.
Re: custum exhaust
i can run without mufflers right?? i hope so . i have seen so many people run with out them but the best part is the dual exhaust i want to do.
Re: custum exhaust
Had a loud exhaust on my Celica, got fed up with it after a couple years. The difference between the loud exhaust and a quiet exhaust was a horsepower *gain* and a much more comfortable ride...
Re: custum exhaust
An improperly proportioned exhaust system will not produce the best power. There are useful harmonics that are lost with improperly sized systems, even an open pipe can have less power output that a properly sized one. Do a little home work and you will end up with a better system, and not waste your time with a poorly functioning system that does not produced good power or economy, and just makes a lot of noise.
This web site has a work sheet for properly sizing a custom system:
http://www.mkracing.com.ar/archive/esca ... ength.html
Good luck, let us know how it works out.
Re: custum exhaust
Aside from the back pressure issue (which is huge) there is also the question of where would you run the pipes?
The stock side has enough room but the other side would be extremely difficult to plumb. You will need, at bare minimum, 1/2in around the pipe in all directions to make sure you don't have any unwanted exhaust-frame contact. Once over the rear axle, then what? There is a gas tank in the way. The proper side has a nice heat shield to protect the tank from exhaust heat. You want to run straight hot pipes front to back
(convertors and mufflers take a lot of heat out the system, that is why they are shielded) a straight pipe back to the rear bumper would likely melt the bumper unless you extend your tailpipe way past the bumper, which really wouldn't make much sense?
Having had loud cars, while cool in the short-term, they can be a real slog on trips.
Re: custum exhaust
Petros is right! Backpressure will also be dramatically reduced is what my T-TEN assistant teacher told me!
K-Business
Re: custum exhaust
a properly tuned exhaust system can actually have lower back pressure than an open pipe that is not tuned. The harmonics can produce lower back pressure (and more hp) in the exhaust manifold if the system is designed well.
There is an ignorant myth running around that some cars make more hp with backpressure, because they compared an open pipe exhaust (assuming it has lower back pressure), with a longer smaller dia system (that was properly tuned). The lower the back pressure the more hp you produce, but a longer and smaller dia system might produce less back pressure than a large and short open pipe, because of proper tuning, taking advantage of the harmonics.
Re: custum exhaust
wow there is so much for me to do befor i even start weell i wil be making a lot of phone call and takeing lots of pics caant wait to hear it when its done. thanks for all of the info.
calvin.
calvin.
Re: custum exhaust
Indeed.. just like two-strokes, you want to maximize the scavenging effect caused by exhaust waves.Petros wrote:a properly tuned exhaust system can actually have lower back pressure than an open pipe that is not tuned. The harmonics can produce lower back pressure (and more hp) in the exhaust manifold if the system is designed well.
Also, you are NOT going to hurt the engine by not having enough back pressure. The only problems caused by this would be incorrect carb. tuning related.
Re: custum exhaust
ok i have not gotten to far. but i know there is three places that will do my exhaust but is is a lot more than i thought like $1000 more the cheapist one was $1,858 so i wont be doing it right now. but my big problem is that my muffler fell of because the pipe roted threw. so my question is if i cut the exhaust pipe befor the rearend and put one out by the the drivers rear tire
Re: custum exhaust
Try this?
viewtopic.php?f=7&t=177
This setup been going for over 5 years...have replaced a glasspack and a rusted clamp.
Check the condition of the converter...exit pipe still solid? Down pipe solid? Buy the ss flexpipe to clamp on it...run it back to a glasspack or other muffler? Later if you need to replace the down pipe and converter you can still use the same ss tubing and muffler.
If you have an original converter...it's worth around $150 for the platinum in it...don't give it away. In fact...you could sell the converter and almost put on a complete new system.
Re: custum exhaust
well takza my exhaust has rotted to just be for the rear end and i need to remove it.takza wrote:Try this?
Re: custum exhaust
well i have gotten to the junk yard and replaced the rear section of exhaust and now have a no muffler exhaust system and dam is it nice more power same fuel economy and very nice sound.
