front dif fluid?
- My tercel:: 1985 Tercel 4wd
front dif fluid?
What should I be filling my front dif with? I replaced the LF axle today and there is very little to no no fluid in the frotn dif, does it get auto transmission fluid, or does it get gear oil?
Re: front dif fluid?
According to the handy factory service manual that I downloaded from the home page, the front diff in an auto Tercel is separate from the transmission and uses plain ol 80-90W.
Ok. I figured it would take gear oil instead of atf otherwise they probably wouldnt have seperated it from the trans.
Thanks
Thanks
