. Also, when the car was raised, tight turns under throttle or while hitting bumps, the axles would grind beyond belief. So much grinding that the steering wheel would pulse.
I had this same problem when I replaced the front springs and struts on my 84. It was even worse when I added a 1 inch riser above the strut mount to get that coveted lift. The new springs gave the front end a higher ride height and so now the cv axles were running at a different angle and grinding. It is aven more pronounced when turning since the angles on the cv joints are tighter in a turn. I just replaced the cv axles and all was quiet again. I guess the cv axles wear in at a certain angle and then don't like to run at a different angle. I had already replaced them once but that was almost 100,000 km ago.
I also had to add a 1 inch lift to the back springs just to even things out after the new front springs. I assume new back springs might have helped but I couldn't find any. As soon as I can get the back up another inch I will throw in the riser on the front again. Hopefully the cv axles will handle that.
I would post pictures of the car but I'm not sure how to do this. Anyone wanna let me know?
