I've been hearing some weird noises under my car recently, so jacked up my car to take a look. I had just finished driving the car a fair amount. I put my hand on the transmission when I was under the car and found it to be suprisingly hot! Almost too hot to touch! :blink: Anybody ever felt their transmission after a bunch of driving? Is this normal? I recently topped up the trans fluid...
FY!: The wierd noises were not comming from the trans.
Hot Transmission?
Where were the wierd noises coming from? :blink:
And a transmission does generate a lot of heat. It's one way people start bushfires without realising it. They take their car off the highway where it's been running failry hard and run it thhrough a paddock. A stem gets just enough energy to smoulder, which is self sustaining and away you go.
The amount of heat generated sounds normal to me.
1983 Tercel SR5 with 185/75R14 tyres, 32/36 DGAV Weber carburetor, lumpy cam and upgraded Pioneer sound system. Veteran of several fire seasons (with the scars to show it) and known as "The Racing Turtle"
With my heated fuel, the line WOULD get too hot to touch and it turned out that the warmest it gets is around 147F...so ALMOST might be around 125-130F?GTSSportCoupe wrote: I've been hearing some weird noises under my car recently, so jacked up my car to take a look. I had just finished driving the car a fair amount. I put my hand on the transmission when I was under the car and found it to be suprisingly hot! Almost too hot to touch! :blink: Anybody ever felt their transmission after a bunch of driving? Is this normal? I recently topped up the trans fluid...
Thanks for the replies all! I'm not too stressed about it now. I might eventually get it checked out by a trans shop, but I'm guessing its ok.
Current:
91 LJ78 Landcruiser EX5
95 A32 Maxima SE
Former:
87 AW11 MR2 Smallport 4AGZE
93 Taurus SHO ATX
86 AL25 SR5 6spd 4wd
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
- My tercel:: None
