Ok, while I was fighting insomnia last night, a pyschedelic chimpanzee came and enlightened me with this gem. Here goes: If a 1c-l (diesel) and a 4a-lc mount into the same transmission, and If a 4a motor can be mounted directly into a tercel with a 3a, shouldn't a 1c-l be transferable to a tercel? (with some work of course) He then hit me with a banana and lept out the window. :huh:
I figure that the 4a and 1c use the same trans from veiled references in my Chilton's manual, and from looking at Napa and Schucks and seeing that the transmission rebuild kit is the same. I would guess that some custom motor mounts might be needed. Of course finding a diesel corolla would be the real challenge here in the states.
Has anyone here had any experience with the 1c? Are they good motors or would I be buying a pricey boat anchor? I'm just asking out of morbid curiosity since I've already got my project that I need to finish.
Diesel Engine
If this was possible, it would be nice to get one of the turbo versions (1C-T, 2C-t, or 3C-TE. The non-turbo version would not really be an improvement over the 3ac powerwise.
It might be necessary to change the final drive ratio of the tercel too. Otherwise you'll run out of rpms at highway speeds.
I think camrys were available with C-T engines.
A 7afe/ge would probably be a better conversion.
Current:
91 LJ78 Landcruiser EX5
95 A32 Maxima SE
Former:
87 AW11 MR2 Smallport 4AGZE
93 Taurus SHO ATX
86 AL25 SR5 6spd 4wd
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
Info on Toyota diesel engines:
<a href='http://www.geocities.com/MotorCity/Pit/ ... gines.html' target='_blank'>http://www.geocities.com/MotorCity/Pit/ ... es.html</a>
Current:
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
The perfect donor option. Can't loose on this price:
<a href='http://cgi.ebay.com/ebaymotors/ws/eBayI ... ename=WDVW' target='_blank'>http://cgi.ebay.com/ebaymotors/ws/eBayI ... me=WDVW</a>
Current:
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
