4A update
We just had our race car mechanic friend take some measurements on the 4A today and its good news. All I need to do is slap in some pistons, rings, and bearings, and new gaskets and I'm good to go. The motor I bought was supposed to have 250,000 miles on it, but its closer to 60,000 (not a typo). It looks like I may be able to pull this off for under $700 total.
- My tercel:: None
Have fun!
The 4a is a direct bolt in block replacement for the 3a. It is only if you get into the 4ag engines where space and routing becomes an issue.
Helliphino.com
Helliphino.com
My only concern with the project is the flywheel. Just from looking at the manuals (which doesn't tell me much) the flywheel on the 4A looks thicker than the 3A. But I will cross that bridge when I see the one on the 3A and compare.
I thought long and hard about the 4ag, but when I saw how much a carb and manifold were, I just about died.
What considerations would I have to face when swapping an '85 Tercel 3A-C 4WD with an '86 Corolla 4A-LC FWD engine?
<a href='http://cgi.ebay.com/ebaymotors/ws/eBayI ... ename=WDVW' target='_blank'>Toyota Reman Engine 4ALC</a> Current price is $315.
Since it doesn't show the engine, I would guess it's only the block and head. Will all the other engine parts from the 3A-C be compatible?
I have found a Japanese 3A-C engine for $455. But was considering an increase to 4A.
<a href='http://www.enginewholesalers.com/tercel.html' target='_blank'>Engine Wholesalers</a>
Thank you for your help.
The 4al is a whole other beast. I believe it was never placed in a rwd situation, therefore it is a whole lot different, as far as location of components, height and length, etc. It was made to be mounted sideways. I am not sure of the specifics, it had been discussed on this forum before, and always with negative swapping comments.
Helliphino.com
Helliphino.com
Fingers: Are you sure you don't mean the 4a-f? I know its, longer and the distributor is mounted funny (in my opinion), but from all the checking I've done the 4a-lc is the same as the 4a. Anyways, thanks for peeing in my Wheaties.
InTech: So far I've found that the distributor and the intake and exhaust manifolds are the same. BUT, I would look at a junkyard and either compare or pickup the parts you need before buying one.
- My tercel:: None
The only differences I know that the 4A-LC's have is the timing belt cover and the fact that it was used in the AE82 Corolla FWD sedan and had around 12 more horsepower than the 3A-C and 4 more horsepower than the 4A-C. Need to check on the horsepower, but I'm positive the HP readings are correct. :blink:
2015 Honda Fit EX "Malachi"
all you need is block and head really (short engine). Everything else goes from 3a-4a real easy (mounts, water pump, sump etc etc).unsure about exhaust manifold, but I am 95% sure.TnTech wrote: What considerations would I have to face when swapping an '85 Tercel 3A-C 4WD with an '86 Corolla 4A-LC FWD engine?
The L in 4A-LC means transverse mounted as far as I know. That would only refer to things that are different between a FWD and RWD setup, like the water lines and the engine mounts. Anything like that can probably be used from the 3A-C since the head is the same and most of the block casting features are the same.
Another update: 8-4-04
Just got the pistons pressed on, which was rather impressive. The guy doing it looks at the pistons, says "I have the tool around here somewhere," then grabs an aluminum dowel, machines and drills it in about 10 minutes, so it'll fit on the piston. He finishes it up with, "ah there it is." We pressed them on and I took the pistons home and ringed them.
Anyways, that was the happy part of the update. I was torquing the bolts for the crankshaft bearings progressing merrily when out of the clear blue disaster struck. One of the bolts torqued to 80ft-lbs out of the 87 that I needed when, wammo, it snapped like a 90yr old's hip. And to make it just that much sweeter I pulled the bolt out and it was two threads too far to get vise grips on. ARGH. I think it would be a wise idea to replace all those bolts now.
- My tercel:: None
Reminds me of what I mentioned before about design limits and metal fatigue...but then I know just about everuthing I guess...... :rolleyes:
Not really slowing me down much though.
