Outfitting the Tercel 4WD for camping....
Been a good while since I've checked out the solar panels:
<a href='http://www.jcwhitney.com/autoparts/Prod ... pId-385937' target='_blank'>http://www.jcwhitney.com/autoparts/Prod ... -385937</a>
This is about 1/3 A...let it run all day in the sun and party at night!
On a more serious note: if you watch how much current you use...1/3 A will go a long way as far as keeping it charged up.
Good idea if the fridge was surrounded by about 5" of styrofoam?3A-C Power wrote: Come to think of it we could tap into the car's existing a/c system and route some of the refrigerant to the evaporator in the bar fridge, eliminating the need for a power source. Those things use R-134a.
Five Watts!?! Try Five AMP's-350 Watt's!!! <a href='http://www.shop1.outpost.com/product/3321552' target='_blank'>http://www.shop1.outpost.com/product/3321552</a> B):D B)..."Can I Get a WITNESS!?!?"...B):D B)
Stuff for getting out of trouble:
twist-in earth auger (3' long) - 2.5lbs
2 hand winches (10' of cable) - 14lbs
shovel...reg with short handle - 3lbs
extra scissors jack - 8lbs
2 1' X1' & 1 1' X 1.5' 5/16" waferboard pieces - 8lbs
2 nylon (?) tow straps both 2" X 25' - 6.5lbs
tow chain - 9/16" X 18' - 14lbs
tow cable 1/4" X 60' - 7 lbs
grand total = 63lbs
* also want to buy a snatch block
<span style='color:blue'><span style='font-size:8pt;line-height:100%'>DID I FOGET ANYTHING?</span></span>
grand total = 63lbs
- My tercel:: None
Found it. That looks like the SAME solar panel as at JCWhitney...5W/350ma....
LINKS:
<a href='http://www.mrsolar.com/Merchant2/mercha ... ate=google' target='_blank'>http://www.mrsolar.com/Merchant2/mercha ... =google</a>
<a href='http://www.partsonsale.com/kyocera.html#kyoceratop' target='_blank'>http://www.partsonsale.com/kyocera.html#kyoceratop</a>
<a href='http://www.4lots.com/index.asp?PageActi ... tegory=205' target='_blank'>http://www.4lots.com/index.asp?PageActi ... ory=205</a>
<span style='color:yellow'><span style='font-size:21pt;line-height:100%'>SOLAR POWER AIN'T CHEAP.....BUT IT'S FREE ! ! !</span></span>
LINKS:
Here's a good place to research digital cameras:
<a href='http://www.epinions.com/Digital_Cameras' target='_blank'>http://www.epinions.com/Digital_Cameras</a>
I usually sort by ratings and then look for those that have maybe 5 or more reviews. This means they've been on the market a while at least......
My camera is similar to this one, but is only 640X480...I can take 1000 pics on the same batts if I don't use the flash...only downside is the lack of a zoom...does have a macro though...I'd buy this camera used even...mine has lasted 4 yrs or so. 2 are new cameras.
<a href='http://www.amazon.com/exec/obidos/tg/de ... ce&s=photo' target='_blank'>http://www.amazon.com/exec/obidos/tg/de ... s=photo</a>
You want the one with 16 MB memory...1.3 megapixel...need a USB port to download photos.
Here's a solution to the camping problem?
Looks good IF you don't want to go offroad a lot.
Would tow real well behind a Tercel.
Takza,I found the Kin'da tent Ive been look'in for.Its Kin'da cheep($40) and its Kin'da ugly...but the dimentions and practicality are good! Witch reminds me of a saying we "hillFolk" use,about the time we relize there arnt e'nuff womenfolk to go~round.We say,"You may be Ugly...But your MY Kin'da Ugly!" !
