So after a few months of driving on AE82 front springs and AE86 rear springs I've come to a verdict on using these.
While these springs to fit and "work", they're defiantly not ideal.
It might be hard to tell from the picture, the front of the car sits up higher than the back, it's more noticeable when looking at the wheel arches.
The problems I've noticed this causing is wind really likes to move the front end around, and in the rear heavy bumps makes the suspension come
really close to hitting the bump stops. Having the front sit higher than the back has also resulted in a bit extra positive camber which I had to correct.
Good news is I held onto the springs that came with the car so I'm going to give them a fresh coat of paint and put them back in.
Personally I wouldn't recommend using AE82 and AE86 springs, but if you're in a pickle for replacement parts they do at least "work".
Verdict on AE86 & AE82 Springs
- Kozuto_98
- My tercel:: 1987 SR5 Wagon
1987 Tercel Wagon SR5 4WD
Re: Verdict on AE86 & AE82 Springs
I am considering installing some front struts and springs from the all-trac corolla, they have the same travel, but are much larger dia. shock/strut, and it comes off a heavier car, so the spring should give a bit of lift.
I have a set i got at a picknpull some years ago, they are just in a pile of spare parts, both need new inserts, I will also have to swap out the upper mount, and likely make a few other minor tweaks.
- Kozuto_98
Interesting. That's something I might look into when I get around to doing the Monroe rear air shocks.
I've seen a couple all-trac Corollas in a yard not long ago so I'll have to see what's left of them. My mom used to drive one so I'll have to see if any
of the parts from it got saved.
- Kozuto_98
The mount on the body is fine, but the rubber is pretty much done. The nut and threads are also pretty rough so I guess my next project will be
making new sway bar links from scratch.
- simon84
I recently did a bunch of work on my rear sway bars. The end link mount bolt snapped on me so I welded a bolt on there. I got new bushings for it from Rockauto. They only had bushings for the end links though.
- Kozuto_98
I sadly can't find anywhere to get the bushings I need for where I need them. I'm gonna try making a set of bar to body links from some steel plates,
bolts, and hockey pucks I've got laying around. These seem fairly straight forward to fabricate. I'll be sure to post some measurements and what not.
SuperPro carries bushings for both the front and rear anti-roll bars on AL25s.
1975 Subaru SuperStar wagon
1987 Subaru RX 3-door
1987 Subaru RX Type-RA 3-door
1987 Toyota Tercel SR5 wagon
1999 Subaru Forester S
2002 Subaru WRX sedan
- Kozuto_98
I'm assuming this is the site.The Professor wrote: ↑Fri Apr 16, 2021 10:02 am SuperPro carries bushings for both the front and rear anti-roll bars on AL25s.
Very nice parts, I am for sure going to try the 4-link bushings they're selling as mine are shot.
Thanks for pointing this out, never heard of SuperPro.
an aftermarket supplier of polyurethane bushings makes generic replacement "doughnut" bushings I was going to try out when mine wear out. they have various sizes, and one of makes a sway bar link ready to go, that can be adapted to the rear sway bar on the T4wd. I have seen the in Autozone, but others have them too.
you might look here:
https://www.speedwaymotors.com/shop/sus ... s~6-16-580
or here:
https://www.summitracing.com/search?Sor ... 20bushings
or here:
No problem!Kozuto_98 wrote: ↑Sat Apr 17, 2021 1:04 amI'm assuming this is the site.The Professor wrote: ↑Fri Apr 16, 2021 10:02 am SuperPro carries bushings for both the front and rear anti-roll bars on AL25s.
I like to use urethane bushings in any joint that doesn't rotate (they'll eventually squeak without regular lubrication.) Anything in a compressive installation is fair game for me, otherwise it's rubber or a spherical bearing.
