info on the 4age for those contemplating a swap
eightyfive4WD
My tercel:: 1985 Tercel 4WD 5 speed wagon
Re: info on the 4age for those contemplating a swap
Post by eightyfive4WD »
Great info! Gives me some food for thought on my grand schemes. I smell a 20V 4AGE, big brake kit, rear disc, suspension refresh and manual transmission swap in my future.
eightyfive4WD wrote: Fri Feb 05, 2021 9:49 pm Great info! Gives me some food for thought on my grand schemes. I smell a 20V 4AGE, big brake kit, rear disc, suspension refresh and manual transmission swap in my future.
if you do not have a manual transmission now, why not find a T4wd with a bad engine and use that as your project 4age "Tercel4wd GTS" project car, rather than attempt that on a DLX with a working drive train now.
that way you will have a working car while to do a ground rebuild up on a rescued SR5.
eightyfive4WD
Petros wrote: Sat Feb 06, 2021 8:19 pm
That is also a good idea! The main issue I'd have with that at the moment is strictly a lack of space and time to dedicate to the project.
In reality it will be a while before I get to any engine swap plans. Maybe not years before brake & suspension upgrades, but I am at a critical point of my Engineering degree currently and time is quite a commodity. So at the moment, most changes I can make to the Tercel will be relatively low-cost and minimally fabricated.
In addition to this, the T4WD I recently acquired is in fantastic shape, and with only 52,000 miles on it. I'm certain I could eventually find another T4 in good shape, but I doubt it would be in a condition quite like the one I recently acquired.
For the moment, I plan to continue to do as many small tasks on my Tercel as I can chip away at while I finish my degree. Thorough detailing & leak inspections, electrical refreshing and overall making sure the Tercel is completely up-to-date on maintenance tasks.
eightyfive4WD
I am considering my time with this Tercel now as my "value building" time. I will get to the fun stuff eventually!
