Rear Lower Control Arm Same?
DanT
My tercel:: 83 Toyota Tercel SR5 Wagon
Post by DanT » Thu Sep 05, 2019 12:00 pm
I need to replace a rear lower control arm on my 83 T4 SR5. I am searching salvage yards on the East Coast. Some internet information suggests that this part must come off of an 83 or an 84, Toyota part number 48720 16040. I am aware that the T4 rear end is the same as the Corolla, so I am guessing an 83 or 84 Corolla would work also.
Is anyone able to verify whether the rear lower control arms for all years of T4's are the same?
It is my understanding that this part will fit on either the right side or the left side, and Is interchangeable.
Any further information on this would be much appreciated.
Thanks,
Dan
Re: Rear Lower Control Arm Same?
Post by Petros » Thu Sep 05, 2019 7:02 pm
all of the Tercel4wd rear axle links are the same, all years are interchangeable. Not sure if the RWD corolla are the same, likely they are because the axle is the same, but the front mount could be differnt.
BTW they usually called trailing arms (not control arms).
DanT
Post by DanT » Thu Sep 05, 2019 7:46 pm
Very helpful to know that the trailing arms are the same for all years. That could make it much easier for me to find one. Thanks for the help. Much appreciated!
Dan
Post by irowiki » Thu Sep 05, 2019 8:14 pm
81 Coachmen RV, 70k miles
95 Camry Wagon, 153k miles
04 Camry Sedan, 250k miles
Post by Petros » Thu Sep 05, 2019 10:52 pm
I have a 1984 T4wd daily driver, and an '85 project 4age swap T4wd in my garage. If I remember I will take a peak at the rear trailing arms on both to see if there is a difference.
it is possible they changed the design of the arm, but the fit and function is identical, and they can be interchanged. but I can not see them changing the body pan (where the forward end mounts) nor the axle mount and location, so I do not know how it would matter. possible they switched to another supplier, used different brand of bushings, etc. so they have different part numbers, but they can be swapped out.
DanT
Post by DanT » Fri Sep 06, 2019 7:06 am
48720 16040 is the discontinued Toyota parts number for 1983–84 showing in the online Toyota diagrams. 48720 16030 is the discontinued part number for newer models. I agree with you that the attachment points on both ends are likely identical. Not sure why they changed the part numbers. If you could take a look that would be helpful to know if you can discern any difference. Thanks, Dan
The Professor
Post by The Professor » Fri Sep 06, 2019 8:40 am
Not sure why they changed the part numbers...
Could be anything, new supplier for the paint, a change in the manufacturing process. The part number changes because releasing two different, yet similar parts under the same part number can lead to problems identifying suspect parts if there is a defect discovered, so they supersede to a new number.
1975 Subaru SuperStar wagon
1984 Subaru Turbo-Traction wagon
1984 Subaru Turbo-Traction hardtop
1987 Subaru RX 3-door
1987.5 Subaru RX 3-door
1987 Subaru RX Type-RA 3-door
1987 Toyota Tercel SR5 wagon
1999 Subaru Forester S
2002 Subaru WRX sedan
Post by Petros » Wed Sep 25, 2019 9:17 pm
I did a quick look under my '84 T4wd, and my '85 T4wd, both the trailing links look the same, visually anyway. I did not measure them.
DanT
Post by DanT » Wed Sep 25, 2019 9:34 pm
Thanks for checking. Yes, that agrees with what I am finding out here also. Any 83-87 T4 wagon should fit. Apparently Corolla trailing arms will not fit our T4 wagons. I have put hours in calling salvage yards in my area (Northeast and East Coast to Baltimore). Unable to get this part around here. If anyone on this list has a trailing arm to sell please pm me. Will pay $35 (common salvage yard rate?) plus shipping. (I will PayPal or pay in advance so no risk for you.) Dan
