3A-L on Valve Cover
Yaut
My tercel:: 1985 Toyota Tercel 4WD automatic, lifted 1.5", 15 inch wheels
3A-L on Valve Cover
Post by Yaut »
I bought an 85' some time back for parts. I noticed today that there is a sticker in the valve cover that says 3A-L. Has anyone seen this. Wonder if this is of any significance or not.
Yaut
Re: 3A-L on Valve Cover
Post by Yaut »
The internet seems to suggest the 3A-L was a transverse engine so perhaps the valve cover just came off of another engine.
Hey Yaut,
As you’ve already found, the “L” apparently indicates a “transverse” engine. I know Chevrolet used the 4a in a trasverse set up for the mid 80s Novas, not sure where else they were used.
likely you have a crate engine (imported) installed. the long block is identical and it will not affect your installation, as long as you plan on swaping over all the extrernal parts, oil pan, mounts, intake/exhast manifold, etc.
should not be an issue for anything your needs.
Yaut
Post by Yaut »
Great. Thank you for the info!
