Leaky front end
Ellisdee
My tercel:: 1985 wagon
Leaky front end
Post by Ellisdee » Wed Jun 19, 2019 8:17 pm
Ive replaced the seals on my front axles, the end that goes into the transmission twice, it still leaks...the seals did not seem tight enough on the axles when I put them on before assembly to check got fit...I know I used the right ones...has anyone else had this problem?
BaileySims
Re: Leaky front end
Post by BaileySims » Wed Jun 19, 2019 9:01 pm
I did just previously. I made the mistake of driving the seal in as far as it could go and that was the wrong answer. I couldn't give you an exact distance per say, but the seal only sits in a certain amount.
WAGON MAFIA.
Blood, sweat and beers.
Yaut
My tercel:: 1985 Toyota Tercel 4WD automatic, lifted 1.5", 15 inch wheels
Re: Leaky front end
Post by Yaut » Wed Jun 19, 2019 10:38 pm
According to the repair manual, the seal needs to be driven in 8.4-9.0 mm (0.331-0.354 inches) from the surface of the case.
'84 Toyota Tercel SR5 4WD (red)
Re: Leaky front end
Post by dlb » Thu Jun 20, 2019 7:08 am
I have consistently had problems at getting these seals in at exactly the correct depth, and had to remove the CV's and reset them a few times. It super sucks. I think it's a lousy design that there isn't some sort of lip in there for the seals to butt up against because measuring the depth all the way around the seated seal is difficult to do accurately, especially when you're lying on your back in the dirt with not much room to work.
Sorry for the rant. To answer your question, if your new seals are leaking Ellisdee, you may want to recheck the depth and adjust them to the spec Yaut mentioned. If you deform them at all you will need to replace them though.
Re: Leaky front end
Post by NWMO » Thu Jun 20, 2019 9:05 am
Hey Yaut,
What page did you find this info on? I've looked through the FSM and page FA-18, but didn't find anything specific to seal renewal. Driving the outside of the oil seal 0.3" past the surface of the case sounds deeper than I would expect, but I don't recall for certain. Is it possibly referencing the actual "lip" of the seal vs the outside face of the seal? I've renewed the drivers side seal on my Tercel and just don't remember driving it that far home.
Elisdee,
Do your new seals look like the Beck/Arnley #0523521?
https://www.rockauto.com/en/moreinfo.ph ... 23&jsn=373
Abletobecain
Re: Leaky front end
Post by Abletobecain » Thu Jun 20, 2019 9:27 am
That's the right seal. Member xirdneh made a sweet little tool for this out of PVC. Hopefully he sees this and can maybe post a picture. I just replaced my passenger side axle on my DD and got lucky carefully tapping it in with a large socket (28mm I think).
2007 Tundra Limited Crewmax 4x4 ("Tetsuo Shima"/Hauler) SOLD :cry:
1987 DLX Tercel Wagon 4WD ("Lil Red") SOLD :)
Re: Leaky front end
Post by dlb » Thu Jun 20, 2019 12:26 pm
Hey Yaut,
From an old post of Tom's:
ARCHINSTL wrote:
Thu Apr 21, 2011 12:43 pm
It's NEEDLESSLY (!) buried in the Differential section of the MT info - look on MT-86, item 15. There is a drawing with dimensions.
In metric, the CV axle seal depth is supposed to be 8.4-9 mm.
Re: Leaky front end
Post by NWMO » Thu Jun 20, 2019 1:02 pm
Thanks dlb (and Tom!),
It does look like, with the proper tool (or something similar) the tool will hit the “stop” when the proper depth is acheived. I need to look up xirdeh’s homemade tool as it would certainly be handy on this job. It looks like a piece of pipe with the OD to match the housing and an ID small enough to catch the new seal is all that would be needed.
Yaut
Re: Leaky front end
Post by Yaut » Thu Jun 20, 2019 1:49 pm
Hey Yaut,
Elisdee,
NWMO,
The info I found was on MT-86, step 15 of the manual. It looks like Toyota had a special tool "SST 09223-46012" to install it the the correct depth. It's hard to tell from the picture but it looks like it's from the outside face of the seal from the surface of carrier. I'm going to feel really stupid if I'm looking at the wrong thing.
Edit: NWMO, I didn't see your previous post until I posted this.
Ellisdee
Re: Leaky front end
Post by Ellisdee » Thu Jun 20, 2019 6:37 pm
Thanks for the info, I’ve ordered two new seals and believe I can fabricate a tool out of pvc pipe...I’ll be so glad to be able to park anywhere without leaving a puddle.
Ellisdee
Re: Leaky front end
Post by Ellisdee » Thu Jun 20, 2019 7:15 pm
I decided rather than make a tool out of pvc...it would be so much easier to turn a wooden one on my lathe...I’ve done this previously to make a clutch alignment tool...I’ll post pics when I get it done.
Yaut
Re: Leaky front end
Post by Yaut » Thu Jun 20, 2019 9:23 pm
Great idea!
MrWrench
Re: Leaky front end
Post by MrWrench » Thu Aug 08, 2019 7:44 pm
If anyone is interested in making a batch of seal driving tools, I'd be willing to purchase one. I repalced my seal twice and have had continual leaks. I feel like I am definitely driving it in deeper than .3 inches.
1991 Toyota Celsior RHD
1988 Volvo 780 Bertone
1980 Volvo 262 Bertone - E85 SBC project
1985 Toyota Tercel SR5. Aka "Spud"
Abletobecain
Re: Leaky front end
Post by Abletobecain » Fri Aug 09, 2019 10:11 am
I just made one following xirdneh's blueprint here:
viewtopic.php?f=10&t=13310&p=102412&hilit=seal#p102412
Worked perfectly.
Re: Leaky front end
Post by xirdneh » Wed Aug 14, 2019 12:53 am
Installing seal too deep seems to increase chance of leaking. I wish i knew why that is? .3" seems to work best.
