What are the extra hoses and canisters between the air cleaner and radiator?
They look stock, but I've never seen this before.
Is this normal?
- My tercel:: 84 and 85 4wd wagons
Is this normal?
Re: Is this normal?
that looks like the California variant emissions set up. Not sure, but Canada may use something similar.
instead of the reed valve chamber on the left side of the engine below the distributor (in the othe lower 48 federal cars). It allows fresh air to be fed into the catalytic converter, this system takes air from the aircleaner housing and injects it into the exhaust manifold below the carburator. That device on the front side of the air cleaner is a similar reed valve that allow fresh filtered air into the exhaust stream, but prevents exhaust gases from getting blown into the intake system.
- LowBuckCanuck
Re: Is this normal?
My Canada spec '86 looks like that.
