Monroe Air Shocks
- LowBuckCanuck
Monroe Air Shocks
Anyone used these? A fellow on another forum says that they bolt right in. I think its on page 2.
https://grassrootsmotorsports.com/forum ... 791/page1/
$60 CAD on rock auto for 2 http://www.rockauto.com/en/parts/monroe ... orber,7556
Is there anything that could be used in the front to have air shocks all the way around?
Re: Monroe Air Shocks
just bolt them on and run the air lines
- LowBuckCanuck
yes it does,pic is at 30 psi and 195-70-14 tires,,i like the ride better than the stock shocks,if you have any loads in the back just add a little air and no saggie rear end
- Mattel
Have these on my corolla 4wd which has the same rear end as the Tercel 4wd. They work really well with the worn springs that are on there already and compensate well for any loads. I think I've written about them here a few times. Do a search for Monroe
- LowBuckCanuck
As always, the forum searches are clear as mud. Am I correct in thinking that if I install a set of the air shocks in the back I don't need any other springs (like from a pathfinder) for a lift?
From what I gather from the searches, there isn't any air suspension options for the front? Does that mean I have to go old school and use some Camry struts or whatnot?
I really wish someone were to document the various ways of lifting a tercel and have it properly organized one of these things:
I imagine this topic comes up very often.
you can lift it how ever you want,,i only about 1" lift so I took the easy route,, the air shocks and 1" strut spacers in the front and the bigger tires it can all be done in a Saturday morning
- Mattel
The searches aren't that hard to do. just takes some time to go through the threads
you might want to chase this up
viewtopic.php?f=3&t=12724&p=99180&hilit=MONROE#p99180
also search for the bartos lift.
If you would like to compile the lift threads into one that would be awesome. We are all volunteers here.
you can also get a 12 volt compressor so you can gain lift from the drivers seat by flipping a switch. Mazda MPV with the load levelor option, Cadillac, Lincolns and Mercedes (and others) all use the same compressor (made in USA), you can buy them in the wrecking yard cheap (I paid I think $12 from a pick-n-pull as a spare for our MPV< but never needed it), you just have to rig them with a manual switch, rather than the suspension height sensor used on those cars. It is about the size of a typial school text book, not too large.
That would be a great set up, when you load up your car, or want to cross a creek, deep snow, etc you just hold a switch until the rear has raised up to the desired height, and away you go. I am seriously considering this for my project 4age/Tercel4wd car. I already have the spare air pump anyway, just need some air line, and some wiring/switch, etc.
- LowBuckCanuck
As I search for the holy grail, I'll try and take own notes. No promises, but I may be able to scrape something together.
To start with, about how many different ways should I be aware of? There's the Bartos Lift, there is an excellent thread by Abra-Cadaver here: viewtopic.php?f=7&t=12433 and then there is the Monroe air lift option for the rear. Not to mention the use of spacers like the one jimcrazy posted... looks like I have my work cut out for me.
Also, for reference, about how much lift can one achieve on the front without compromising the cv joints? Its all for research purposes.
- LowBuckCanuck
I think a onboard compressor is a great idea, but would be even better is there is air suspension on all 4 wheels. I'm not aware of any air shocks for the front, but I'll look into it.Petros wrote: ↑Sun Feb 18, 2018 3:39 pm you can also get a 12 volt compressor so you can gain lift from the drivers seat by flipping a switch. Mazda MPV with the load levelor option, Cadillac, Lincolns and Mercedes (and others) all use the same compressor (made in USA), you can buy them in the wrecking yard cheap (I paid I think $12 from a pick-n-pull as a spare for our MPV< but never needed it), you just have to rig them with a manual switch, rather than the suspension height sensor used on those cars. It is about the size of a typial school text book, not too large.
- LowBuckCanuck
there are no air struts I am aware of for the Tercel, they are likely some available for other models of Toyotas which may be able to be adapted.LowBuckCanuck wrote: ↑Sun Feb 18, 2018 3:51 pm I think a onboard compressor is a great idea, but would be even better is there is air suspension on all 4 wheels. I'm not aware of any air shocks for the front, but I'll look into it.
I saw a set of air adjustable front struts for a subaru at a garage sale for like $60. I almost bought them to see if I can make adapters to make it work on my terel, just to show off to all you guys. but I was not that motivated and would have likely end up costing a lot more than I thought it was worth (I do not trust my welding skills, so I would have to pay a skilled welder to make the adapters).
You can buy these inexpensive doughnut air assist balloons that will fit in spring of the front struts, might be worth a consideration. Just expect to have to replacement them regularly. see below.
- LowBuckCanuck
I think after all the research I did to make the list of ways to lift a tercel, I have settled for basically what jimcrazy has done. 1 inch spacer in the front, Monroe MA700's in the back. The adjustability is very attractive. Could of used a set yesterday when I had 8 tires and 4 rims in the back of Lenny.Petros wrote: ↑Thu Feb 22, 2018 4:04 pmthere are no air struts I am aware of for the Tercel, they are likely some available for other models of Toyotas which may be able to be adapted.LowBuckCanuck wrote: ↑Sun Feb 18, 2018 3:51 pm I think a onboard compressor is a great idea, but would be even better is there is air suspension on all 4 wheels. I'm not aware of any air shocks for the front, but I'll look into it.
Also interested, did you make those yourself jimcrazy?
