Banging noise when braking
- My tercel:: 86 sr5
I have been getting a loud banging noise while braking for some time now. It sounds like it's coming from the rear. It was time for a brake job anyway so I went ahead and replaced pads, shoes, rotors and drums. There was no change to the noise. It seems to be less prominent in 4wd. Any thoughts?
I was hoping it was in the brakes, but it appears that it's not. I checked the driveshaft and the u-joints appear to be tight (well tight for 170k). There is quite a bit of play in the rear diff but I don't feel anything weird in there. I changed the diff oil and there weren't excessive metal shavings or anything. I'm stumped. My next step is to swap the diff and driveshaft with the parts car, but I don't want to just throw parts at it.
- helipilot77
- My tercel:: 1984 SR5 wagon
Re: Banging noise when braking
I also have a mysterious noise coming from that area of my car although mine is more of a rattle. Sounds like chain clinking. I can't find it anywhere and I've been under it several times. I thought maybe it could be a carrier bearing but it also feels tight. I might have to put it up on my friends auto lift and have him run it in 4WD and listen.
. / TOYOTA
./_| |/|/ |]
./_| |/|/ |]
Check rear shock, top mount nuts
I would never have thought of that!
Update: I checked the rear shock mounts and they are tight.
- My tercel:: 85 wagon4x4
I am not sure what yours maybe but I do know on my jeep I had the same issue and I did the brakes and replaced the shocks all that stuff finally I just looked at everything and it wound up being a heat shield rubbing on the drive shaft so I just ripped it out (the heat shield) no more problem.
Is there anything else happening when you brake? The steering wheel doesn't pull to one side or anything?
If you are not sure where it is coming from, have someone sit in the back when you brake to tell you if the sound is actually coming from there.
I have had someone drive while I ride in the back and it's definitely coming from there. I can feel it through the brake pedal, which is part of the reason I did the brake job. No pulling or anything like that.
Hmm, have you checked the bushings for the rear trailing arms (not sure if that is the correct name)? Get in there with a pry bar and check for movement.
Has your helper been able to determine if the noise is coming from one side?
I have checked all of the bushings and haven't found anything out of the ordinary. I'll probably replace all of them at some point, just for maintenance purposes but they seem okay as of now. The spring bushings seem a bit tattered but it doesn't sound like a spring rubbing on the perch. I'm probably just going to live with it until it either breaks (whatever it is) or until I get ready to refresh the rear suspension/axle/driveshaft. Thanks for all of the suggestions guys. This site is truly awesome!
Welcome to the forum Poc,
Bad bushings might allow the diff/axle housing to rotate too much and the banging comes from the u-joint on the front of the diff assy. bad wheel bearing could cause it too, though usually you get other symptoms when not braking with bad wheel bearings.
There is a proportioning valve in the system that goes to the rear brakes, might be possible that is malfunctioning. But I have not ever heard of that causing banging. Usually it either stops working, or it locks up.
I was going to try and live with it but after driving to work today, I'm going to try changing out the driveshaft for the one out of my parts car, even though all of the u-joints feel tight. I'll change the center support bearing while I'm at it.
I have a similar issue,
a low/moderate bumping thumping rubbing sound while gently braking at low speed,
under 15mph, coming from the rear.
Only when I am barely pressing on the brake,
it is quiet with no brakes, or heavy brakes.
No significant noises or vibrations at higher speeds.
I'm thinking maybe a warped drum, bent axle, loose axle bearing,
or loose broken bent or improperly installed brake shoe hardware.
Have yet to dig in and diagnose.
ok it is only banging when you break? they why would you mess with the driveshaft? I would say if you have done the breaks and shocks and just about everything you can think of- I can add some of my experiences I used to build mustang hot rods when I was younger and usually when crap like that happens we found it to be wheel hop -yep wheel hop -when you break the wheel vibrates if you put anything other than factory spec wheels usually larger as in taller or fatter we almost always had weird things happen that made strange ghost noises it could even be a shackle on the real leaf spring or something vibrations do weird things but I bet it is all connected to wheel hop -this can happen when you break lightly or when you take off we used to put traction bars on to keep the hop at a minimum but for these raging 62 horsepower monsters a person might never ever think about -wheel hop!
oh and I am not making fun of the tercel -I love the things.
