Heater Lever
- My tercel:: 83 SR5 stock
Heater Lever
Hello all!
I just purchased my first Tercel in September, it's a bronze 83 SR5. I love it.
When I bought the car it did not have a working blower. Also, I noticed that the heater lever wouldn't go all the way to hot, only just past half. I replaced the blower motor and upon inspection of the levers I noticed the problem. As you all know, the air adjustor lever (vent, heat, defrost), and the heat lever are sort of connected. The heat lever has a wire that passes through the adjustor lever. I can see that this connection is buggered up and not allowing the lever to move all the way over to hot. I've tried to adjust it back to normal position by rebending the wires, but I just made it worse. Any solutions that don't involve replacing the whole lever board? Do I just live with it? The air is warm. . .
- Gottolovem
Re: Heater Lever
You can manually turn the "valve" to hot from under the hood.
Re: Heater Lever
My control valve is also sticky, so as Gottolovem mentions, I unhooked the wire and manually move the lever to full Open or full Closed at the beginning or end of a season.
- My tercel:: 1983 4wd Wagon
Re: Heater Lever
I do the same thing, manualy turn the lever for the season. I suppose there is a right way to fix it, but Its rather tight in there.
Re: Heater Lever
usually the heat lever gets stiff becuase the control valve is stiff and/or the cable needs lubrication.
this is what i do
1. remove cable from control valve located on fire wall pasenger side and has two rubber hoses attached to it.
Work its lever back and forth while applying light lube oil top and under.
2. raise end of cable and drip some oil in the end, then wedge it in one of the holes under the car hood to keep it elevated. Re-apply oil several times over an hour. the oil will work its way down the cable.
3. do not force the heat lever as it will weaken and break. gently move it back and forth till free
if this does not work there must be another problem
this is what i do
Re: Heater Lever
Hey thanks guys!
I'll be working on it tomorrow. I'll let you know how it goes!
Something else happened, though. The replacement blower motor that I mentioned replacing failed. It lasted two days, 5 hours run time max. Any ideas on what's going on?
Re: Heater Lever
where was the fan made, in a communist owned factory in the orient, or in Japan?
the factory fans are pretty reliable, a used factory fan from a wrecking yard is usually better than a new or re manufactured one from a third world country.
BTW, it helps a lot of use silicone lubricant on the heater lever panel innards. a lot of plastic-on-plastic contact there, I use the silicone spray to lube the levers, and all the pivots and linage under the dash.
- helipilot77
- My tercel:: 1984 SR5 wagon
Re: Heater Lever
Are you certain that it isn't the resistor that went out? Odd that even a cheap motor would go out that fast.
. / TOYOTA
./_| |/|/ |]
./_| |/|/ |]
Re: Heater Lever
when resistor goes bad you usually lose one or two speeds
i believe high speed will still work with a totally bad resistor
- Jonymoto
Re: Heater Lever
My blower stopped working a few years ago. I took it apart and found out that the motor brushes were worn. I got new brushes from an auto electric shop and solders them in. The blower is still working today. I remember it was a bit awkward getting the blower out. I've done the same with my alternator.
Re: Heater Lever
"where was the fan made, in a communist owned factory in the orient, or in Japan?"
Important distinction. In Japan, I pulled it out of an 89 corolla at the pick n pull in Spokane. Also, I am certain that the resistor is bad. It is broken and I can only run on high. Maybe I shouldn't have been running it without the resistor?
Also, I did lube the levers. Through, I need to lube the cable housings. Like xirdneh lays out. I saw a post her about using some old wiper tubes.
Re: Heater Lever
unfortunately half the "new" parts made in China are junk right out of the box, so even a new one could be bad. Usually the Japan or US made motors are pretty good and reliable. You put a used one in and it soon failed, perhaps it was sitting too long without running got some internal corrosion, usually used ones are fairly safe bet. Perhaps not with the one you got. I doubt it was because it was run without a resister, all that means is it just would always run on high setting, which actually I do not find that useful. I do not like the noise and find that I actually get more heat at a lower setting (I presume because the air goes over the core slower, picking up more heat).
Re: Heater Lever
@ rc26: See this link on clever way to lube cables from inactive member c_j (it even shows heater cables being lubed!): viewtopic.php?f=7&t=9549&p=89760&hilit= ... ion#p89760
I've used it and it works great!
