IN DIRE NEED FOR A FRONT WHEEL HUB
I am an 18 year old student my daily driver is my beloved by many 86 tercel sr5 i have tried my hardest at finding a front wheel hub and understand its a really hard part to come by if any of you guys have a good condition wheel hub i am in desperate need i have other parts i can trade or money thank you all for your time
Re: IN DIRE NEED FOR A FRONT WHEEL HUB
where are you located? what exactly do you mean by "hub"? do you want the steering knuckle assembly? or the part that the end of the CV axle spline shaft goes though with the big nut on the outside?
What exactly is wrong with your old one, does it need new bearings and seals, or is there metal damage?
Can you post a picture?
BTW, the front steering knuckle and wheel flange on the T4wd is common to all '83-86 Tercels, front wheel drive and four, two door hatch back, 4-door and wagon. It would give you more models to look for at local wrecking yards. This would not be true of the rear wheel assembly, but it true for the front.
