What have you done to your wagon lately?
Re: What have you done to your wagon lately?
put a new set of sneakers on it Friday and painted my roof pod to match the car today,getting ready to go to stan fest july 1st weekend
WOW, does that look GOOD!
Nay - GREAT!
PROPS!
Since my Goldie is the same "Topaz." what is the lower body color? OE or your idea?
Nay - GREAT!
PROPS!
- helipilot77
- My tercel:: 1984 SR5 wagon
That does look very sharp!! Nice work!!
. / TOYOTA
./_| |/|/ |]
./_| |/|/ |]
- My tercel:: 1984 Tercel 4WD
Hey Jim.
That looks AWESOME!!!
- Jonymoto
I love those lights on the bumper. Can you post a close up photo please to show how they are mounted? Are they fog, driving or spot lights?
hi jony they are a cheap light made by pilot pl-282c,they call them driving lights for off road use only, we have a law here that you must have day time running lights or your head lights on in the day time so I leave them on all the time in case I for get to turn on my head lights. they come in a kit lights,wire and switch for 20.00 bucks,, a far as mounting them they have a u-shaped bracket and I just took out one of the 6mm bolts that holds the rubber on the bumper and just used the one bolt to mount them, will take some pics tonite
- BaileySims
Looks awesome! Great picture too. I have been working on getting my car on those rock auto magnets. That car is s dam good candidate.
WAGON MAFIA.
Blood, sweat and beers.
i have only started getting a few things from rock auto lately now that the shipping to Canada is feasible Bailey..... jony heres is a couple of pics of the lights. and one pick for Tom the paint can brand and color code
Thanks - gonna look for it!
- BaileySims
You don't have to order anything from them to have your car featured. I do order a lot of stuff though.
WAGON MAFIA.
- BaileySims
Just a friendly reminder to keep an ear out to anything that doesn't sound right on your tercs. Posting this as I am currently stranded awaiting a tow truck because my sway bar bracket fell off.
WAGON MAFIA.
- 4wdEconoBox
Ewwww, that doesn't sound like fun!! Nothing bad happened though did it? I do have a sound coming from my front end, but I'm pretty sure its just my cv axle being noisy... Hopefully....
when ever I am doing any work under the car I always inspect all the fasteners, and if possible put a wrench on them and check that they are tight.
It is rare that I find one loose, but occasionally I do. I drive 6 miles of gravel roads everyday, three out from the house, and three back home, and it tends to do a number on anything that moves on the car, working fasteners loose. I have had the nut at the top of the strut mount back off and the end of the strut pull out, I have also had the large flange nut on the top of the strut tube, that holds the cartage into the strut tube, back out and have the cartridge rattling around.
- BaileySims
Something happened alright. I think the joint on the axel closest to the transmission toasted itself. I brought it home yesterday to look at it and it just drove like absolute hell on the way home. It shakes really hard only under load. I'm hoping it is just the cv, nothing else looked out of whack.
WAGON MAFIA.
usually the inner cv joints do not fail (they have a smaller angle on it that the outer ones), it is usually the outer ones that go first.
I quick test is to try and rotate the axle by holding it on each side of the CV joint, it should not have any noticeable rotational movement. badly worn CV joint will rotationally move over a 1/4". note that the plunge, or telescopic movement of the joints is normal, and not a reason for concern.
good luck
good luck
