Valve cover gasket
Valve cover gasket
Post by irowiki » Fri Nov 08, 2013 2:29 pm
Which valve cover gasket do I need?
Funny thing is both of them claim to be used on 80-86 tercels, but one is clearly different!
http://www.autozone.com/autozone/parts/ ... 73_18416_0_
and
http://www.autozone.com/autozone/parts/ ... 13_69522_0_
81 Coachmen RV, 65k miles
95 Camry Wagon, 135k miles
04 Camry Sedan, 213k miles
Re: Valve cover gasket
Post by Petros » Fri Nov 08, 2013 3:08 pm
those are pretty much the same, but you will also need that half circle plug too. get the top one. you will still need to put sealant on the have circle and in the corners of the front cover where it goes over the front camshaft journal.
