4WD shifter / shaft seal size (& also driveshaft seal size)
Re: 4WD shifter / shaft seal size (& also driveshaft seal size)
Post by xirdneh » Sat Oct 03, 2015 12:47 pm
ended up ordering thru Grainger online
around 7.00 apiece including shipping when i ordered 4
part SKF 552505 16x24x7 mm
JDNightFox
My tercel:: 1986 SR5 / 1987 SR5
Post by JDNightFox » Sun Dec 20, 2015 11:22 am
So I'm going to check for sure once I receive them but I'm pretty sure I found the shifter seal, rear driveshaft seal, and front CV seals on O'Reilly's website for about $6 each
Post by xirdneh » Sun Dec 20, 2015 12:18 pm
i just received a bunch of seals from colonialseal.com
after shipping was figured in they came to 4.50 a piece.
i converted inches to mm which made it easy to find the four sizes i needed
Post by Petros » Sun Dec 20, 2015 2:34 pm
that is a good resource, you should make a separate thread with the Colonial seal part numbers, cross referenced to the Toyota seal name and part numbers so it will be easier to find next time someone on the forum needs to locate them.
JDNightFox
Post by JDNightFox » Sun Dec 20, 2015 5:18 pm
Yeah they had to order mine so they should be here Tuesday-ish. Mine were National brand, and with my 10% off it was $51 for complete seals for both wagons: 4 CV's, two shifters, and two rear driveshaft outputs
Shifter: Part #221410 http://www.oreillyauto.com/site/c/detai ... ord=221410
CV Outputs: Part #223240 http://www.oreillyauto.com/site/c/searc ... ord=223240
Rear driveshaft: Part #223252 http://www.oreillyauto.com/site/c/detai ... ord=223252
I'll see how well they work when I actually get them, it listed the dimensions in the description which was nice
Post by xirdneh » Mon Dec 21, 2015 1:55 pm
Shifter: Part #221410 is that for a 2wd tranny shifter
JDNightFox
Post by JDNightFox » Tue Dec 22, 2015 4:24 pm
xirdneh wrote:Shifter: Part #221410 is that for a 2wd tranny shifter
It's for the 4wd lever on the 4wd models
Post by xirdneh » Tue Dec 22, 2015 11:04 pm
i have some 221410 seals that i ordered years ago thinking they were for fwd shift lever but they are too small
the following are the correct seals
4wd Shift Lever Seal in Transfer Hsg. Timken 16x24x6, SKF 552505, ColonialSeal.com size AS 16x24x7. Hole in tranny .938dia, Shaft dia .628”(16mm). Seal about .593” ID(15mm) x .954 OD x .235 Thk,
JDNightFox
Post by JDNightFox » Wed Dec 23, 2015 9:23 am
Yeah that's the dimensions listed on the 221410
ADDITIONAL DETAILS
Material: Nitrile
Outside Diameter (In): 0.954 Inch
Outside Diameter (mm): 24.23mm
Series: 220000
Shaft Size (In): 0.551 Inch
Shaft Size (mm): 14mm
Type: 35
Width (In): 0.276 Inch
Width (mm): 7mm
Post by xirdneh » Wed Dec 23, 2015 10:47 am
but you listed 221410
1 vs 3 a few posts back
JDNightFox
Post by JDNightFox » Wed Dec 23, 2015 5:43 pm
xirdneh wrote:but you listed 221410
OH I didn't even notice. Yes that's a typo it's 221410
Also I just popped the new seal onto my 4wd shifter earlier and wow it's a very good fit on there over the old one. I doubt it's going to leak ever again
Post by xirdneh » Wed Dec 23, 2015 11:54 pm
ok now i'm confused
i have some 221410 and they are too small for 4wd shift lever
are you sure that number is correct?
221410 or 223410
i bought those 221410 seals about 8 years ago, maybe the number was right but wrong seals in box?
JDNightFox
Post by JDNightFox » Thu Dec 31, 2015 10:44 am
xirdneh wrote:ok now i'm confused
221410 or 223410
Yes it's 221410
The ones I got now fit perfectly, I'm not sure what happened with yours but they definitely gave me wrong seals on other occasions so maybe that's what happened
pbtv
My tercel:: 1985 SR5
Post by pbtv » Mon Nov 12, 2018 1:14 pm
Update:
For xirdneh's cross reference of the 4 seals from Colonialseal.com, see this post
viewtopic.php?f=16&t=11801
For what its worth, I ordered all "AS" style seals and will update if I have any issues.
