Lower Radiator Hose for 1 1/8 outlet
tercle
My tercel:: 1985 SR5
Post by tercle » Wed Oct 19, 2011 10:35 pm
Here is what I found about molded lower radiator hoses:
The Gates 21311 is 1 1/8" at the engine and 1 1/4" at the radiator outlet.
This appears to be the more common Tercel hose.
The Dayco 71276 is 1 1/8" at both ends.
I picked up a used aftermarket radiator at a parts yard a few weeks ago, and the outlet is slightly smaller than the old one.
After some searching, I found out there are at least two types of molded lower hoses.
Hope this helps someone else.
celtglen
My tercel:: 84/2WD/Wagon-stock/311+K miles-original engine/original owner/ no mods
Re: Lower Radiator Hose for 1 1/8 outlet
Post by celtglen » Tue Oct 25, 2011 6:37 am
There are a bunch..what I use is a hose sealant which helps.
