AM Beck-Arnley Trans Front Output Seal
Post by ARCHINSTL » Tue Apr 19, 2011 7:35 pm
There seems to be a lot of confusion among parts houses on the seal for the front driveshafts into the differential. I don't have the Toy OE number (probably bigga bucks), but here is the Beck-Arnley number - and a picture.
Note that it some parts places show it as NOT having a lip - that is NOT correct.
Beck-Arnley # 052-3521
Also see this link: http://www.tercel4wd.com/viewtopic.php? ... eal#p41102
c_j
My tercel:: T4WD#4: '86 SR5 6-speed, original Barto lift & steel bumpers & winch, also 95Amp alternator
Re: AM Beck-Arnley Trans Front Output Seal
Post by c_j » Wed Apr 16, 2014 6:33 pm
A reverse cross-reference from this Beck-Arnley seal gives this Toyota OEM number: 9031132006
Here is a list of supposed aftermarket equivalents (do your due diligence before ordering):
Code: Select all
223240  Timken
223240  B.C.A.
223240  National
P223240 Parts Plus Bearings & Seals
12754   SKF (CR)
550237  SKF (CR)
5566912 Victor Reinz
Post by irowiki » Wed Apr 16, 2014 8:21 pm
This is the timkin one, it looks odd:
81 Coachmen RV, 70k miles
95 Camry Wagon, 153k miles
04 Camry Sedan, 250k miles
Post by Petros » Wed Apr 16, 2014 11:13 pm
that is not the correct seal, that is used somewhere else on the trans, it would not fit.
Timken uses a plain seal without the dust rib shown on the face of the seal in the picture above. It fits dimensionally but without that rib dirt and small stones will get under the metal dust shield on the cv axles and slowly grind it away. so the timkin one likely would not last as long. find one that has that dust rib like the beck-arnly one.
Post by irowiki » Thu Apr 17, 2014 12:07 am
That's what I thought. All the ones labeled "automatic transmission front output seal" were actually the 223240 one.
I'll try the manual transmission one and see how it matches up.
Post by xirdneh » Tue Jan 27, 2015 10:23 pm
in the past i ordered National/Timkin # 223240 and they had the lip
the last order thru rockauto of # 223240 had no lip
SinusoidalTendencies
My tercel:: 87 4wd wagon
Post by SinusoidalTendencies » Thu May 09, 2019 7:23 pm
Why would RockAuto not update their menu after so long with a team member even on the forum to be informed so..?..
putting "Beck-Arnley # 052-3521" in the search bar brought it right up though...so make sure to look it up by part #
maybe we'll get lucky though and RockAuto will pick up their slack
jimcrazy
Post by jimcrazy » Tue May 21, 2019 3:39 pm
go to manual trans and drive axle seal on rockauto
jimcrazy
Post by jimcrazy » Sat May 25, 2019 3:32 am
just got a bunch of stuff from rockauto yesterday the wholesaler closeout list,,,got 5 of the 223240 seals lol couple of bucks each not out much
Post by Petros » Sat May 25, 2019 5:00 pm
I had the same issue like this, not really Rockauto's fault. I think the manufacturer is unloading mislabled inventory on them. At a few bucks each, there is no practical way for the seller to verify the correct part is in the box before they ship it.
I guess the thing to do is order more than you need, and than toss the incorrect ones (or save them just in case you might find a use for it some day).
