OE part numbers, as obtained from Butler Toy September 2010.
The first price is regular OE retail - the second is Butler's. Note that all are quite competitive with AM parts and better than other Toy dealers.
04421-12011-77..Bearing kit...................57.73.....2 @ 43.30.....86.60
42454-20010......Bearing retainer LH.........8.46.....1 @..6.35.......6.35
42424-20010......Bearing retainer RH.........8.46.....1 @..6.35.......6.35
42185-52030......Gasket axle housing end...7.89......2 @..5.92.....11.84
42425-52030......Gasket to retainer..........2.43......2 @..1.82......3.64
94181-11000......Locking shoulder nuts......1.66......8 @..1.25.....10.00
90311-42055......Oil seal.......................5.56......2 @..4.17.......8.34
Total USD 133.12 for OE parts vs. USD 177.42 regular OE pricing.
Ordered 0901 - Butler received from warehouse and shipped 0903 - received 0907 (Labor Day 0906).
While irrelevant - the Toy replacement for the axle gasket is plastic instead of metal (I guess it discovered that steel rusts...) and the same plastic is used for the retainer gasket instead of fibre.
EDIT 03/20/2012 - I had transposed the numbers for the OE bearing retainers; they are now corrected.
OE Rear Axle Bearing, Retainer, Seal, Bits Numbers
Re: OE Rear Axle Bearing, Retainer, Seal, Bits Numbers
tom, what comes in the bearing kit? i was thinking that it would have the bearing, retainer, both gaskets, and oil seal, but am not sure.
And propably a quicker wear with the plastic so they can make more money! Funny how the economy works! Spend money to find cheaper ways to make the stuff so they can sell it for more!
Labine R.
Labine R.
It is listed as a "kit," but is actually just the bearing and its inner retainer - the latter locks the bearing in place. Look at page RA-25 in the FSM.
What Toy shows as the "bearing retainer LH and RH" is actually in the FSM as "bearing outer retainer." They are different for each side.
BE SURE to look at https://tercel4wd.com/forums/viewtopic.php? ... ing#p42555
See EDIT above for corrected numbers; dlb caught this.
- My tercel:: T4WD#4: '86 SR5 6-speed, original Barto lift & steel bumpers & winch, also 95Amp alternator
Rather than starting a new topic, here some aftermarket part numbers for rear axle bearings and brakes, etc. that I used to refurbish a rear axle recently:
Code: Select all
Rear Drums 9331R Raybestos
Front Emergency Brake Cable BC92968 Raybestos
Left Rear Emergency Brake Cable BC93849 Raybestos
Right Rear Emergency Brake Cable BC93363 Raybestos
Rear Brake Hold Down / Return Spring Kit H17196 Raybestos
Left Rear Brake Adjuster Kit H12502 Raybestos (only listed for 2wd, but worked on the 4wd)
Right Rear Brake Adjuster Kit H12503 Raybestos (only listed for 2wd, but worked on the 4wd)
Rear Wheel Bearing 30BCDS2 Nachi
Rear Wheel Bearing Lock Ring C06 Koyo
Rear Wheel Cylinder P9424 Ultra-8
Rear Differential Carrier Gasket RDS27411 Fel-Pro (bolt holes didn't line up very well, but it worked)
Rear Brake Hose H2183 CEF
Brake Hose Retainer Clip H1457 Carlson (universal part)
