ISO carburetor choke breaker diaphragm filter and hoses
Shanemt
My tercel:: 1983 sr5 4wd wagon
Post by Shanemt » Fri Aug 16, 2019 6:05 pm
This like plastic piece broke when I touched it on the back drivers side of the carburetor, and appears to be the choke breaker diaphragm filter. It says aisin 3a27 on it. I’d like to replace the hoses too, but I could also probably reuse them. Any help is much appreciated!
Abletobecain
Re: ISO carburetor choke breaker diaphragm filter and hoses
Post by Abletobecain » Mon Aug 19, 2019 11:09 am
That's a one way check valve I believe. You should be able to replace it with a generic aftermarket one that fits.
I'd replace all of your vacuum lines if your check valve is that brittle...likely the lines are too. You can get a roll of silicone hose on eBay for around $20. Get the 3.5mm...works perfect.
2007 Tundra Limited Crewmax 4x4 ("Tetsuo Shima"/Hauler) SOLD :cry:
1987 DLX Tercel Wagon 4WD ("Lil Red") SOLD :)
