Genuine Toyota Rear Seatbelt Info & Part #
GLet71
My tercel:: '87 6-spd SR5 4wd Wagon
Post by GLet71 » Mon Apr 24, 2017 7:34 pm
I've been looking to add 3 point seatbelts to the back row, and came across this Toyota service bulletin from 1988...
Re: Genuine Toyota Rear Seatbelt Info & Part #
Post by irowiki » Tue Apr 25, 2017 11:06 pm
Sadly I think those don't exist anymore and is why I had to move away from tercels :(
81 Coachmen RV, 70k miles
95 Camry Wagon, 153k miles
04 Camry Sedan, 250k miles
Post by Mattel » Wed Apr 26, 2017 10:31 am
We have three point in Australia for the two outer seats (still lap in the middle). I did send some over for Thom a few years back. If you look under the C pillar trim I would imagine there is a bolt that you could fit a seatbelt two from a corolla or something similar. even a set of fronts from a wrecked Tercel? and dremmel out the trim to fit around it.
GLet71
Post by GLet71 » Wed Apr 26, 2017 11:12 am
I've ordered non retractable belts off of eBay that will work, just need to manually adjust them. The issue with retractable, and not being able to use any old variety, is the necessity in being level vertically and horizontally. The Aussie specific ones have all that into account, because yes, the welded nuts are all in place as you say.
I had hoped to just transfer front belt assemblies to the back but it isn't possible to fit them in there level.
GLet71
Post by GLet71 » Wed Apr 26, 2017 11:19 am
Mattel wrote:We have three point in Australia for the two outer seats (still lap in the middle). I did send some over for Thom a few years back. If you look under the C pillar trim I would imagine there is a bolt that you could fit a seatbelt two from a corolla or something similar. even a set of fronts from a wrecked Tercel? and dremmel out the trim to fit around it.
If you come across two more, send 'em my way!
Post by Mattel » Thu Apr 27, 2017 7:26 am
Hi Glet I dont' get to the wreckers much but if I do i will look out for some!
GLet71
Post by GLet71 » Thu Apr 27, 2017 7:50 am
Mattel wrote:Hi Glet I dont' get to the wreckers much but if I do i will look out for some!
Cool, I would like to make sure my kidlets are safe and sound in the back seat, so if you come across a pair, please let me know.
