aisin carburetor part number?
boomerbabe
My tercel:: 1984
Post by boomerbabe » Fri Mar 18, 2016 11:34 pm
Hi all - I have a 1984 tercel wagon with the 3a engine - but the carb is toast. Does anyone know the part number for this carb? thanks!
tercel4wdrules
My tercel:: 83 & 84 SR5 4WD wagons
Re: aisin carburetor part number?
Post by tercel4wdrules » Sat Mar 19, 2016 12:13 am
The part number that ends in 15340 is the most common.
2003 Honda Accord DX 5 spd MT - "Quinn"
1998 Toyota Corolla CE 4 spd AT - "Russell"
Post by irowiki » Sat Mar 19, 2016 5:04 pm
Pretty much any carb from 83-86 (and 87-88 wagons) will work, you may just have to adjust what vacuum lines plug in where.
81 Coachmen RV, 65k miles
95 Camry Wagon, 135k miles
04 Camry Sedan, 213k miles
Mark
Post by Mark » Sat Mar 19, 2016 9:27 pm
boomerbabe wrote:Hi all - I have a 1984 tercel wagon with the 3a engine - but the carb is toast. Does anyone know the part number for this carb? thanks!
I'll be the first to ask... How do you know the carb is toast? It would be a shame to go to the trouble and expense of replacing it when maybe it's just a disconnected vacuum hose or something.
Post by xirdneh » Sun Mar 20, 2016 12:42 pm
sometimes its hard to know for sure
i usually swap carb with spare known good one to find out
some symptoms i have had that seemed to be carb
assuming all vac lines are correct
blaas out when stepping on the gas (turned out to be a few drops of water in carb)(once it was the ball bearing at bottom of accelerator pump that had popped out)
AAP diaphram leaking (just needs new diaphragm or disconnect vac hose and plug both hose and port)
bad gas mileage
excessive flooding
carb is very dirty inside
will not idle (this is most common thing thing has happened to me)
rebuild kits range from 15.00 to 40.00
there is a video on youtube for taking apart and putting back together
