Bulk Purchase of Vacuum line
JackWagon
My tercel:: 1986 Toyota Tercel Wagon FWD
Post by JackWagon » Tue May 05, 2015 10:09 am
I have small vacuum leaks in a couple of places and would like to replace all of my vacuum line. I remember reading a thread where another member did the same thing and I think the length of hose was 14'. Is that correct?
jimcrazy
Re: Bulk Purchase of Vacuum line
Post by jimcrazy » Tue May 05, 2015 5:42 pm
just done mine last week it takes the 14 feet of 5/32 hose
lannvouivre
My tercel:: 2006 Pontiac Vibe
Post by lannvouivre » Wed May 06, 2015 8:28 am
I used whatever amount comes in the Prestone packages. The small ones that aren't behind the counter. I still need to do more fuel hoses and I think the PCV hose, plus a slew of o-rings.
Post by Petros » Thu May 07, 2015 12:38 pm
make sure you get the right kind of line. Vac lines should be fuel resistant, as well as fuel lines. Line subject to motor oil need to be designed for that application (like the PVC), and water hoses need to be compatible with the chemicals in antifreeze.
They are not interchangeable, if you mix them up they will swell up and decompose fairly fast.
drege
My tercel:: Hadatercel
Post by drege » Mon May 11, 2015 1:28 pm
jimcrazy wrote:14 feet of 5/32 hose
