For sale: first generation AW11 toyota mr2 project car pair. $1000 OBO
In 2013 I purchased the 1986 mr2 as a running, driving car. A coworker of mine was supposed to do the body work on it and paint it, in trade for an ae86. He replaced the quarter panels on it, drove it until he blew up the engine, took it apart and stripped the paint, and then tried to cheat me out of it AND the other car. I managed to get what is left of the mr2 back.
I planned on painting it myself and putting it back together but I just don't have time, and need to get it sold before moving. This come with lots of parts and extras. It has eibach springs installed, a pair of new rear tokico blue struts, new 1987 size front rotors, 1987 rebuildable front calipers and brackets (a common brake upgrade) new front and rear brake pads, and much more. Tires have very few miles on them and hold air.
I also have a new gallon of "Nason ful-thane" 2k urethane paint as well as a gallon of primer and all the reducers and hardeners needed.
It has been stored indoors.
Last year a friend found the 1985 hardtop behind a local mechanic shop. It has sat since sometime in 2013 when the shop installed a new clutch, only to have it not start due to no fuel. Owner gave it to the shop instead of fixing.
It is complete, but has a fair bit of rust in the rockers, floor pans and underbody. Rear window has been broken but is intact enough to keep water out. Car may be salvagable, but also could supply most everything needed to rebuild the '86. Tires are trashed. It does have the early rear sway bar
Engine turns over smooth, and should run with some fuel pump /wiring work.
When shop pulled it off their lot, they damaged the muffler and rear cv axles. Ones in other car are good.
Both cars will need to be towed, plan on putting on a trailer or flatbed as brakes are sticky from sitting.
Cars are located in Roseland, VA
PM me or email me (Jon) @ Johnny_C63@NOSPAMyahoo.com (take out NOSPAM, my non-robot comrades)
http://imgdump5.novarata.net/fwq0xe.jpg
http://imgdump5.novarata.net/zarniu.jpg
http://imgdump5.novarata.net/l6x96q.jpg
http://imgdump5.novarata.net/j6qo58.jpg
http://imgdump5.novarata.net/vw8gyh.jpg
