T4WD ads on Craigslist, 1/19 thru 1/27/2018 (CA, IL, NE, MT, MS, OR)
garyfish
Post by garyfish »
listed in order of newer to older ads
PLEASE NOTE that I am not the seller of these vehicles! Please contact the seller through the info provided in each Craigslist ad.
near San Luis Obispo, CA
https://slo.craigslist.org/cto/d/1984-t ... 39013.html
1984 Tercel DLX wagon, automatic transmission, 215K -- $2600
Date of listing: 1/26/18 (first listed in late Dec.)
I am selling the DLX 4WD Wagon with moon roof & original factory roof rack. The motor is a 4AE which was purchased in the later 90's, have receipt. I have all repairs receipts for all parts & work. I have quite a bit in New parts i have yet to install as well. All of the parts i have sought out have been factory first, most are discontinued however. Then Denso|Japanese, nothing of Chinese origin. I have 7500.00 into this vehicle. The original owners owned the vehicle until 2013, a kid purchased it and had it for 1 year exactly. I have had it since. The lower half of the engine needs work, valve work i believe. It is not running at this moment. The Tercel has been smogged and registered. The Tercel is in great shape minus the lower engine work needed. I have too much money in this vehicle. Thank you for your time
List of New items: All parts have 5k miles give|take
-Toyo tires
-New KYB struts|shocks & strut mounts
-New muffler
-New Cat(California Emissions) Magna Flow
-Bushings
-OEM Toyota Factoy Head lamp Housing upgrade(replaceable bulbs) w/ Hella bulbs
-rebuilt factory distributor(sent to Portland specialist)
-new water pump & Timing belt
-new Toyota factory Head Gasket, i bought the last two within Toyota inventory. still have 1 remaining
-new Toyota factory old stock from Japan EGR valve
-new interstate battery
-new koyo radiator & lower|above hoses
-rebuilt Toyota original with vehicle factory carb
-New Denso starter
-thermostat
- fuel pump
-brake lines
-have new old stock Australia rotors in box yet to be installed
-factory toyota pads
-toyota factory master cylinder yet to be installed
Again i have all paperwork, this list is off the top of head so there are other new parts
805.709.6357 -- Stephen
Rockford, IL
https://rockford.craigslist.org/cto/d/8 ... 70542.html
1985 Tercel SR5 wagon, 170K -- $700
85 Toyota Tercel wagon 4 WD. Car runs good but something in the trans or transaxle broke. Car is 6 speed manual but will not drive due to that. Has new steering rack and struts.Newer radiator, new timing belt
central Nebraska
https://northplatte.craigslist.org/cto/ ... 81789.html
1986 Tercel SR5 wagon, 230K -- $500
Date listed: 1/25/18
86 Toyota Tercel wagon for sale. Clean title, runs and drives. Rusty but trusty. New tires all around. 4WD engages fine. Great beater for winter. Interior isn't the best either. High miles, about 230k but she starts every time. This is the model with the Extra Low gear in 4WD to get you out of mud/snow/rocks/etc. please text me if you have questions. Three Zero Eight 212 Zero Zero 54
near Great Falls, MT
https://greatfalls.craigslist.org/cto/d ... 19030.html
1988 Tercel SR5 wagon, 188K -- $850 obo
Good running car for being 30 years old. A/C and heater and defrosters in front and rear work great has block heater that works for those cold mornings "never failed to start this winter at all since owning it", sun roof works with no leaks, all lights, blinkers and etc work with no issues. I have blue tooth adapter to plug into lighter to play music from devices or answer phone calls.
Issues: 4th gear does not work all others work, sensor on dash for emergency brake will not turn off (brake is not stuck in on position just sensor), cassette deck does not work (radio does work) 30 year old car does burn some oil but no leaks, will need to replace tires soon (rear). Minor wear and tear on car see pictures.
Asking $850 OBO I have all receipts for work done on it since purchasing it.
northern Mississippi (near Memphis, TN)
https://memphis.craigslist.org/cto/d/19 ... 93984.html
1986 Tercel DLX 4WD wagon, automatic transmission, 120K -- $3500
I have a 1986 Toyota 4X4 Wagon with cold AC, Automatic transmission, Power steering and Power brakes. I bought it from the original owner 2 years years ago in Hot Springs AR.
It is in MINT condition with only 120,000 miles. I have replaced the timing belt water pump and radiator since I've owned it. New tires. Alpine AM FM CD Player. Gets Good gas mileage and will last another 30 years ! There are 2 small dents in it as shown in the pictures. The reason I an selling it is because I have too many vehicles. I have 8 cars :( Also for sale are a 1979 Pinto Wagon and an 1986 Toyota Cressida, and a 1976 Celica GT $9,500 in show room condition.
Call me at 901-650-3424.
Portland, OR
https://portland.craigslist.org/mlt/cto ... 51790.html
1987 Tercel SR5, 100K on new engine -- $2200 obo
Date listed: 1/23/18
A Beautiful Hard to get 87 Toyota SR5 4wd!Has SL Gear W/ 6 speed manual transmission!! Shifts from 2 wheel to 4 wheel drive smooth. Motor is new with just under 100k.Very strong.New Clutch grabs good also at 40k. Transmission shifts smooth. Clean title!!! Good tags tell 2019. All lights works. Doors and windows work. Heater works great. Interior is almost mint condition. I love the relibility of these cars. Never really has problems and always Starts right up!. It still drives great after 31 years, and the occasional repairs needed are inexpensive. This car still gets between 28 and 35 mpg!This is a Crazy reliable soon-to-be-vintage/Classic/Collectable car.0 Rust very nice stock Vanilla cream paint.Clean oregon title. Ready to roll out. Steal this car for 2200 obo.First come first served. Thanks for looking! !
near Roseburg, OR
https://roseburg.craigslist.org/cto/d/1 ... 29529.html
TWO Tercel 4WD wagons (1984 DLX w/ auto trans., clear title, 295K) + (1984 SR5, stuck in gear, MISSING TITLE, 237K) -- $500 for the pair (previously listed at $350 each)
Date of listing: 1/20/18 (first listed in early Jan.)
I have two Toyota Tercel 4X4 Wagons for sale for only $500. for both! One is an automatic (runs but has a blown head-gasket)
The other is the SR5...strong running engine, newer radiator & starter, but it's stuck in a gear and I can't seem to shift it out of it.
Great project for someone. All the glass is good........no dents or rust on either! Come take em away for $500. Both are 1984
Rednecklawrence
My tercel:: 5.5 Tercels total... Not enough
Re: T4WD ads on Craigslist, 1/19 thru 1/27/2018 (CA, IL, NE, MT, MS, OR)
Post by Rednecklawrence »
Wish kijiji was as populated with terc's as American Craigslist is
