SOLD
siebzy
My tercel:: 1985 Tercel SR5
SOLD
Post by siebzy » Wed Sep 27, 2017 3:23 pm
Tercel has to go. Fire sale. Just got the brakes checked and its bad. Needs calipers, pads, rotors, hoses on the front. Rears are about to go and leaking fluid. Quoted at $1500 in work by the shop.
1985 Tercel SR5
Manual
209k miles
Engine, trans good
Some dings and dents, shows its age
Good snow tires on it.
Burns some oil.
No muffler.
$500 or make an offer. You haul.
More Photos: https://imgur.com/a/6CvWn
siebzy
Re: '85 Tercel SR5 FS. Seattle WA area.
Post by siebzy » Wed Sep 27, 2017 3:31 pm
Oh yah clean and clear title too.
Re: '85 Tercel SR5 for sale. Seattle, WA area.
Post by Petros » Wed Sep 27, 2017 9:05 pm
sounds like it has a vacuum leak in the fuel system, or the carb is out of adjustment. Both area easy and inexpensive fixes, you just need to find the problem, should not take more than 15-20 min to fix it presuming no major component has failed that is causing the stalling. In every case I have seen these symptoms, it was either a vac leak (easy fix) or the carb was out of adjustment. slight possibility it is a bad AAP, which is also a reasonably easy fix, but takes the right part (not costly). If the AAP in the carb was bad, you would also be getting really poor fuel economy because it would be running rich.
fix the brakes and the muffler, and you can likely get $2500 or more for it.
When you sell any car that is not in drive away condition, you have to discount it heavily. If you need a quick sale, it is perhaps worth $600, as is. Unless you can find an enthusiast who knows how to fix it, than it might be worth about $900.
The other items are minor and common with cars this old, but mushy brakes, stalling and and no muffler means it needs repairs before it can be registered.
So, it is worth it get those items fixed. It wills sell quickly, and for a good price. It will go to someone willing to pay the price to keep it nice.
siebzy
Post by siebzy » Thu Sep 28, 2017 1:49 pm
It's old enough that in WA it doesn't need an inspection to register...
Makes sense on the brakes. I'll get those dealt with for sure and look into the muffler.
siebzy
Post by siebzy » Thu Sep 28, 2017 1:57 pm
Petros - I think you're right on with the AAP being bad. I've been getting crappy fuel economy, and it smells like its running rich.
Post by Petros » Fri Sep 29, 2017 5:00 pm
quick test is to pull off the vac line to the AAP and see if it has fuel in it. If so, than just cap off both ends, it will drive fine after warm up. the AAP only is engaged on cold start up.
not difficult to replace if you can get the part for it, a new diaphragm. may need to buy a carb kit to get it, but there used to be a few places that would sell just the AAP diaphragm by itself.
siebzy
Re: '85 Tercel SR5 for sale. Seattle, WA area. $1200 OBO
Post by siebzy » Tue Oct 10, 2017 11:24 am
Updated! Looking for $1200 if I can get it.
