A white SR5 all the way over in Minnesota, comes with parts.
https://minneapolis.craigslist.org/ram/ ... 05574.html
1985 Toyota Tercel 4WD SR5 wagon - $1500 Minneapolis, MN
- GLet71
- My tercel:: '87 6-spd SR5 4wd Wagon
Currently:
Formerly:
Formerly:
Re: 1985 Toyota Tercel 4WD SR5 wagon - $1500 Minneapolis, MN
I'm confused, the stock carb is a two barrel too?
95 Camry Wagon, 170k
97 4runner, 275k
97 4runner, 275k
says '85, which looks like it is, but has inclinometer installed, and has blue rear seat, tan front. Looks like a mish mash of different parts, not bad condition considering it lives in the rust belt. but there is a lot of rust mitigation that needs to be done to save it.
This rare one from the rust belt needs to be saved, someone should make the owner an offer, $1500 seems a bit optimistic considering it needs work.
- splatterdog
Pretty sure that is emmahumpfritters old wagon. It's not from here, but the 5 years or so it has can be very damaging. MnDot is on a mission to dissolve everything. I spend way too much time replacing brake lines and frames..
