https://youtu.be/J0la_4t56Rc
will be listing on craigslist in a week or two
near Bremerton Wa
1983 twotone for sale western wa
Re: 1983 twotone for sale western wa
here is the history 1983 Toyota Tercel SR5 4wd Wagon
Summer 2013. Picked up Two-Tone Tercel in Portland, Oregon. Had bad Transmission Input Shaft and Bearing, bad front wheel bearings, bad steering bellows, bad inner tie rods, bad stabilizer bar bushings, bad tail pipe & muffler, bad brakes, bad rear axle bearing, bad pinion seal. Interior needed lots of cleaning.
Fixed Tranny has new input and output seals,
1. Bought for 200+ 100 gas.
2. Bought engine (Late Summer 2013) from guy in South Seattle for 250 + 50 gas, he said it was a good engine with around 160,000 miles on it (his favorite).
3. New Front Wheel Bearings and Seals 110.00
4. New Front Brake Hoses 12.00
5. New Front Brake Pads 12.00
6. New Stabilizer Bar Bushings 52.00
7. New Inner Tie Rods. 25.00
8. New Steering Rack Boots. 24.00
9. New Left Rear Axle Bearing and Seal 40.00
10. Installed New Right Rear Axle Seal 3.00
11. Exhaust gaskets, muffler and pipe 64.00
12. New Rear Brake Shoes 13.00
13. New Timing Belt 9.00
14. New Rear Main Engine Seal 9.50
15. New Front Main Engine Seal 3.00
16. New Clutch, Pressure Plate, Throw-out Bearing and Pilot Bearing 117.00
17. New Seals for Transmission and Transaxle 20.00
18. Spark Plugs (old ones look good)
19. Replace Driver Side Mirror (supplied by Petros) New Glass 5.00
20. New Rear Differential Pinion Seal 4.00
21. New Rear Differential Gasket 1.00
22. Replaced shifter with one less worn
23. Cleaned seats and floor carpet with KABOOM 15.00
24. Wire wheeled rust spots and primed and painted
25. Valve cover gasket kit 12.00
26. Alternator belt 6.00
27. Cam Seal 4.50
28. Radiator (from yellow car)
29. Replaced Driver Side Window Regulator
30. Paint 2.00
31. Brake Master Cylinder 46.00
32. Oil and Filter 16.00
33. Air Filter 6.00
34. Antifreeze 16.00
35. Brake/Clutch Pedal Pads 10.00
36. Carb to Exhaust 40mm Hose 7.50
27. Repaired Passenger Side Window Regulator
28. Brake Fluid 3.00
29. Cleaning fluids for upholstery and carpet 20.00
30. Distributer Cap 8.00
31. Vacuum Advance 17.00
32. Pedal pads 10.00
33. Hose Clamp 1.00
34. Swapped Dashboard Gauge Cluster (heat gage was bad)
35. Swapped Climate Control unit (busted lever)
36. Title Change 77.00
37. Light bulbs 10.00
38. Outdoor Carpet for back end 4.00
39. Thermostat 6.00
40. Spare Keys 7.00
41. New Reman Alternator no cost
42. Radiator Flush 5.00 1434.5 total
thats most of it, i know i missed one or two things
Tires only have about 11,000 miles on them
27. Cam Seal 4.50
30. Paint 2.00
33. Air Filter 6.00
33. Hose Clamp 1.00
39. Thermostat 6.00
40. Spare Keys 7.00
Re: 1983 twotone for sale $1600.00 western wa
i love the exhaustive thoroughness. this thing deserves a loving home. i'd just die if some rat child bought it and promptly rear-ended someone after all this care and work.
- Mad_Marx
- My tercel:: 1986DLX (K.I.A. by a Texting Driver, currently being uses as a parts car) 1986 SR5 AC, Cruise, Sunroof a.k.a. TERC II Electric Boogaloo (restoration in progress). 1984 SR5
is this the same guy that did all the "how to" videos? Wish I could fit another Tercel in the collection...
yeah, xirdneh is rob, aka the tercel how-to video guy.
if you put it on craig's list, you should list it for about $1000 more ($2600), you will sell it in one day at that price. IT is a fantastic deal for $1600 with all the repairs and new parts on it.
agreed.Petros wrote:if you put it on craig's list, you should list it for about $1000 more ($2600), you will sell it in one day at that price. IT is a fantastic deal for $1600 with all the repairs and new parts on it.
Sounds like a plan, I might go for for 2200
why leave money on the table? go for $2400 at least. if you like the buyer (seems like a guy that would take care of it), and he agrees to sign up for Tercel4wd.com, than give it to him for $2200.
