86 toyota tercel sr5 - $3500 (los angeles)
- My tercel:: 83 Toyota Tercel 4WD SR5,85 Toyota Tercel 4wd SR5,86 Toyota Tercel 4wd SR5 complete for parts,81Toyota tercel SR5 liftback old school
Re: 86 toyota tercel sr5 - $3500 (los angeles)
is like tr4 with diamonds crusted in dash board?probably you only see this in east LA.thats a common area for those type cars
- Gottolovem
I'd get a mini van to if my dad gave me that
swarovsky crystals vehicle designed for east LA,where you need bodyguards after 10 pm night ,to go out of the house
- My tercel:: T4WD#4: '86 SR5 6-speed, original Barto lift & steel bumpers & winch, also 95Amp alternator
3 antennas? chrome rear view mirrors? I would hope that the bejeweling took place after dad passed it on. The chrome, he can get away with.
"pimp my ride"! in Los Anglese, we used to call those kind of cars "econo-pimps".
most of that can be undone, anyone notice the two inclinometers (or extra gauges or something in an inclinometer housing). It appears to have about 200k miles. If it is mechanically sound and rust free, a reasonable price. Particularly if it passes emissions test in CA.
is that right california is very hard to pass emision?
- shop air blow gun between driver seat and console for those chrome air horns under the hood
- 4wd selector indicator grafted into console (shows 2H, 4L, 4H, N)
- neon light tube on rear hatch (wired to rear defogger switch?)
- hood scoop on the hood scoop
- cornering lamps in the rear view mirrors
Oh dear god, they added even more photos since I first found it. Originally there were only 3, 2 exterior and the cluster/steering wheel. I think "Midlife crisis" is a fitting name for that wagon.
- Gottolovem
It's a rhinestone Cowboy Car
WHAT HE WROTE!Vienna wrote:Oh dear god, they added even more photos since I first found it.
Now - where is the shag rug?
Oops - wrong decade...
the delorean talk in the tshirt thread made me realize that this car is missing the gullwing door mod to really be complete.
in California you are not exempt from passing the bi-annual emissions test, no matter the age. You have to keep all of the factory emissions parts, all have to be in working order, you can not put ANYTHING on the engine that was not factory or California air resources board approved, not even an exhaust system (cat back is okay only), not even an after market air cleaner. you have to pass both a visual inspection to verify no mods, and than a multi speed dyno run at different engine loads, all phases of engine test must pass all various emissions output limits. Even engine swaps are not allowed. Of course most inspectors do not know the differences between and 3ac and a 4ac, but you still have to have all the components on and in working order. If it fails any part of the test, you have to fix it, and than pay for another test, or take it to a crusher.
they are hoping that when your older "polluter" car can not be kept running, you will send it to the crusher. because the seller must guarantee emissions test, a car that does not pass is only worth about $300 in scrap metal, and it gets sent to crusher.
California has been a good source of cheap Tercel4wd since in my state, and most states, of older than 25 years, it is exempt from passing. not California, you have an old car it must get off the road. You can not even put it in your back yard, you have to keep registration current, and pass tests, or face fines. lots of good Tercel4wd, and other classics, go to the crusher in Calif.
- Mad_Marx
- My tercel:: 1986DLX (K.I.A. by a Texting Driver, currently being uses as a parts car) 1986 SR5 AC, Cruise, Sunroof a.k.a. TERC II Electric Boogaloo (restoration in progress). 1984 SR5
Dual clinometers, why didn't I think of that?
thanks petros for california advise emission
