old non-working forum links
Talk about Forum Improvements or anything about the forums.
Post by dlb » Fri Nov 15, 2013 12:54 pm
there are some old links on the forum that will not work due to a server change that occurred a few years ago. if anyone comes across a link on the forum like this:
http://www.tercel4wd.com/forums/viewtop ... 16&p=28985
all they need to do is click that old, non-working link to open it in a new window. it should bring up an 'error 404' screen or something like that. then you can just remove 'forums/' from the URL of that non-working window so it looks like this (minus the spaces—i had to add them so the full URL would show up here):
http:// www. tercel4wd.com/viewtopic.php?f=2&t=3916&p=28985
hit enter, and the link should then work.
Neu
Re: old non-working forum links
Post by Neu » Tue Nov 19, 2013 4:56 am
Report the post as well. We can manually edit it.
Post by dlb » Wed Nov 20, 2013 1:06 pm
you're the man, chad. hella thanks for continuing to make this site work, even when you have no terc to call your own. that's dedication!
Neu
Post by Neu » Mon Oct 13, 2014 12:07 pm
dlb wrote:you're the man, chad. hella thanks for continuing to make this site work, even when you have no terc to call your own. that's dedication!
I still love these cars and plan on purchasing another. :)
Post by irowiki » Mon Jan 12, 2015 9:03 am
We can now unstick this topic. All old forum links will work now that we're back in /forums/
All "new" forum links will work too, thanks to redirection. For example,
http://www.tercel4wd.com/viewtopic.php?f=2&t=8103 which is posted in the FAQ, will seamlessly redirect to viewtopic.php?f=2&t=8103
Once we do a forum upgrade I'll go through and fix every link, but this will do for now.
81 Coachmen RV, 70k miles
95 Camry Wagon, 153k miles
04 Camry Sedan, 250k miles
pordog65
My tercel:: 87 t2 87 t4
Post by pordog65 » Tue Mar 31, 2015 11:30 pm
I open a lot of the car for sale posts ..most of them are
by gone cars on cl..no longer up.
Just Sayin.
Post by irowiki » Wed Apr 01, 2015 7:05 am
Not much we can do about that! That is why whenever I post a CL ad here I try and copy over the text and some of the pictures.
Post by dlb » Wed Apr 01, 2015 9:00 am
if a car sells, the seller probably takes down the ad. people are just linking to the ads here so they are naturally a time-sensitive thing. if you're looking for another t4, you have to keep checking regularly.
