toyota carburetor sst
Look around here for some great advice on getting the most out of your tools! Tips and tricks!
metalonmetal
Post by metalonmetal » Fri Jan 25, 2008 11:34 pm
i'm looking up the recommended special service tools listed in the manual. anybody know of a good replacement or alternative to the carburetor adjusting guage set? (09240-00014)
Abletobecain
Re: toyota carburetor sst
Post by Abletobecain » Sat Sep 28, 2019 1:13 pm
Bump...same question
2007 Tundra Limited Crewmax 4x4 ("Tetsuo Shima"/Hauler) SOLD :cry:
1987 DLX Tercel Wagon 4WD ("Lil Red") SOLD :)
Post by Petros » Mon Sep 30, 2019 10:01 pm
I looked it up on line, I am not sure how this tool is used.
From the picture it seems a feeler gauge should work, or if it is for measuring a gap or throttle position, a caliper perhaps?
I thought a lot of that kind of adjustment was set at the factory, and not intended to be field adjusted.
how is that tool used?
Abletobecain
Post by Abletobecain » Tue Oct 01, 2019 9:37 am
It measures the pitch of the valves at different configurations...fast idle, open throttle, etc. It seems to me that if I cut two small metal (sticks) to the same length that I could put one on either side of the valve and place a protractor flush with one of them (with the pivot at the end) then use the protractor arm to touch the tip of the other stick and read the angle. Would the trouble be worth it? Has anyone rebuilt a carb and performed this step?
Post by Petros » Wed Oct 02, 2019 12:34 am
I have rebuilt lots of carbs, I have never felt the need to do this. my question would be, so what do you do if this measurement is out of spec? can you adjust it? replace it with one of a different value? or is it just something fixed at the factory?
Abletobecain
Post by Abletobecain » Wed Oct 02, 2019 9:47 am
Yes, you can adjust all of them. You bend different parts to adjust...stop levers for the primary and secondary, the throttle kick up lever, unloader lever, etc. I think I'm just going to skip it and see how she runs.
Abletobecain
Post by Abletobecain » Mon Oct 14, 2019 2:35 pm
I swapped the carb without checking any of the valve angles and she's running great now. Glad to know that part isn't necessary...at least in this case.
