1) Drain and remove radiator. Remove radiator fan, front plastic grill, and air cleaner. The grill is just held on but 1 screw and 4 plastic clip things.
Don’t hesitate to get this stuff out of the way. It all comes out pretty quick.
2) Remove distributor cap so you can see what cylinder is in firing position.
3) Remove #1 spark plug. (You can remove them all and then the engine turns over easier with a ratchet on the crankshaft pulley bolt.)
4) Remove the top plastic timing belt cover. The top part will come off easy with the crankshaft pulley still on.
5) Remove valve cover. Remove the top plastic timing belt cover. The top part will come off easy with the crankshaft pulley still on. The lower part need the crank pulley removed. Then you can confirm that no valves are open and in danger of being hit by a piston coming up. If you have to or want to, you can rotate the camshaft with a socket on the camshaft bolt (14MM).
6) Remove whatever drive belts you have. Remove the main crank outer pulley (4 bolts), and the water pump pulley (3 bolts) They come off pretty easy.
7) Rotate the engine with a socket (17MM on mine) on the crankshaft pulley until #1 piston is at it’s low point. (I poked a screwdriver in the sparkplug hole to tell when it was down). With the valve cover off you can also confirm that the cam is not turning, which assures you that the timing belt is indeed broken.
9) Rotate the engine counterclockwise with the socket on the crank pulley bolt until the engine doesn’t rotate anymore.(The rope has bunched up the the cylinder and stopped the engine from turning) Now use a breaker bar on the ratchet and turning counterclockwise. (Yes, counterclockwise like any normal bolt) I started to wonder if it had reverse threads since it was so hard to get off but it’s a normal bolt.
10) When the bolt is out, use a pulley puller to get the pulley off. Don’t try to beat it with a hammer or pry on it like I did. I took a chip out of the pulley trying. There is just enough room in front of the pulley with the plastic grill out of the way to use a puller.
11) Remove the bottom plastic cover, and the timing belt guide. If the belt stripped out at the bottom of the crank timing cut the belt and remove it.
12) Remove the idler pulley bolt, pulley and spring. Pay attention to how the spring hooks on.
13) From here follow the shop manual, that’s what I did. The manual is very good.
14) I used the rope method of holding the engine to torque the crank pulley.
I did have a problem when I was all finished. My car wouldn’t start. After checking everything, I ended up following the procedure for distributor removal and replacement. I think I screwed up and had the distributor pointing 180 deg off when I put the new belt on. Anyway after the distributor R&R the car started and ran. And now it runs better than ever.
Tools: Screwdrivers, pliers, 3/8â€Â
