Located on the Olympic Penninsula.
1987 Toyota Tercel SR5 4WD wagon. 181,000 miles. Interior and exterior both in excellent condition. Engine is running rough and will need to be replaced soon. Blue gray exterior, sun roof, velvet edged upholstery. $650.00 or make offer.
"I've had it checked out by two good local mechanics who both recommended engine replacement. The last mechanic checked cylinder compression and said all 4 cylinders are low; 135 when they should be around 175, but all 4 cylinder compression levels are even."
http://olympic.craigslist.org/cto/2023874550.html
EMAIL ADDRESS: heidim [at] olypen [dot] com
Someone should definitely save this beauty
- My tercel:: 1985 tercel 4wd
Re: Someone should definitely save this beauty
Good chance that a week of soaking the rings with Seafoam, followed by an oil change and an Italian tune up would bring up the compression.
- splatterdog
Checking valve timing would be a good idea.
Sure wish these nice fixer uppers popped up around here.
- My tercel:: '86 SR5 6 speed
Fitting those 13 inchers with cement tires and throwing 'er into the Hudson would do some good?!?4wdchico wrote:... and an Italian tune up....
- My tercel:: None
I've been wanting a T4WD like this one, but they just don't show up like this down here, what a shame. If it popped up here, I'd be all over it.
2015 Honda Fit EX "Malachi"
Perhaps he discovered the seller's pet name for the Terc is "Luca Brasi..." ?danzo wrote:Fitting those 13 inchers with cement tires and throwing 'er into the Hudson would do some good?!?4wdchico wrote:... and an Italian tune up....
