1983 3ac carb interchange info needed
neonsport
Post by neonsport »
The Corolla had a 4AC engine, and the carb is different. Many of the different 3AC tercel carbs will work with a little swapping of the vacuum lines. I bought a Holley remanufactured stock carb for a 1982 Tercel, and it took about 20 minutes for me to swap the lines and one piece of linkage to make it work.
