4AFE swap, guys?
thebigbread
4AFE swap, guys?
Post by thebigbread »
What about a 4afe for my wagon? i know the 4afe has a 6-bolt flywheel. the 4age has more power, but its 8-bolt. And basically anything i can get for a 4age i can get for the 4afe.
1984 2wd wagon, "bottle rocket": http://www.myspace.com/1984tercel
1995 Isuzu TFR-S, "Shorty": no cardomain page yet
Starfire
Post by Starfire »
Its gotta be better than a 3AC!
If you want to make your life easier you could always use a 4AFC.
Typrus
Post by Typrus »
The 4AF"E" Is fuel injected.
4A= A family, 4 subgroup
F= dual overhead cam, economy angle
E= Fuel injected.
You can always convert a 4AFE into a 4AF.
C= California Emissions, not Carburetor.
Someone installed a 5AFE in theirs and converted it to a 5AFE with Weber carb. They said it was a beast.
4AFE= 102HP@5800 RPM
101ft/lb@4800 RPM
So its just above the trannys limit. If you are very gentle, you're tranny MIGHT last.
Did I emphasize MIGHT?
shogun
Post by shogun »
ive tried to find a 5af, but here there is no engine available, i bet it would be easy as hel to turbo charge it
keith
Post by keith »
Try this
http://cgi.ebay.com/ebaymotors/Toyota-1 ... dZViewItem
There are a couple others on ebay as well. But wouldn't that distributor hit the firewall?
Iain
Post by Iain »
Question: (for ony one who knows...)
How would you relocate the distributor from the transversely located motor to the tercel? Would you use the 3a assembly? If so, does it bolt in?
Sorry, that's three questions...
-1992 TCR10 Previa LE -Thanks Jetswim-
-1987 AL25 Tercel SR5 -Sold To Jetswim-
-2000 PL2000 Neon LE -Sold to spencersummerfield-
-1999 PL Neon SE -Stolen, recovered cut in half. R.I.P.-
-1987 AE86 Corolla GT-S Coupe - Sold (I want it back!)-
keith
Post by keith »
Actually C does not = California. It doesn't appear to mean carburated either as I 've seen it on fed engines, Canadian engines and injected engines. Not sure if it stands for anything.
waynehoc
Post by waynehoc »
I was told by one of the guys in my local Toyota dealer parts department that C = 'catalytic converter'
keith
Post by keith »
Wayne, I think your right. In the service manual, all the engines that have a cat end in C, those that don't have a cat, do not have the C. But the manual does not break down the letter designations.
Typrus
Post by Typrus »
I have seen several 3A's (not 3A-C's) that have a cat. My grandmas Camry has a VVT-i Inline 4 (I think its a 2zfee or something odd like that) with no C at all yet it has a cat.
Maybe C doesn't officially mean anything at all? Just that everywhere I've seen it, the breakdown has labelled "C" as "California Emissions"
shogun
Post by shogun »
you dont relocate, you give a little love to the fire wall, banging the hell out of it, at least that is what japanese people do when slaping in a 20v on a ae86
keith
Post by keith »
I'm pretty sure it doesn't really mean anything. Look here
viewtopic.php?t=2033
Its Mickey-D's pics under his hood in new member section. Its a 3AC fed. Mine is just like his but it's 3AC Cal. Its just coincidence that in the FSM under emissions, all 3AC's have cats and 3A's don't. Apparently all 4wd's have 3AC's.
thebigbread
i dont know bout the distributor, but i there is an external coil available for the 4afe. the coil is located inside the distrib, right? :?
Typrus
Post by Typrus »
Read into our transmission discussions.
Starfire
Post by Starfire »
The C indicates a california spec emissions system for the year of the engine.
It may or may not have a cat, depending on the time of implementation.
U is for the japanese spec emissions package.
