I,m going to bum out most of you hi-HP trannie smashers with a little background on heattreat.I am not an expert,but I may have a little shop time.
Generally,for economic reasons,blanks of a medium alloy steel,like a chrome moly,would be pre-heat treated then made into gears.These steels don't get real hard,like Rc 34 or so.To get a hard gear,the gear blank would be pre-machined with extra finish steel left on.Then,thru nitriding or casehardening a hard surface,tough core part is made,but it gets heated to a dull red 1400 f or so.At this point,the crystals change,then the steel is quenched.Warpage and size change are inevitable.The gears would not be usable till it was finish machined,probably ground.All that costs.To retro-heattreat existing gears is unlikely .High production gears are also made by powdered metal processes,requiring big investment.
To have something custom made,better start with a set of Toy engineering drawings.Reverse engineering has its pitfalls.Trannie parts are quite precise.
I don't mean to put a wet blanket on the fun of imagination.I'm suggesting the devil is in the details.Unless you have a great deal of resources(Powerball) or unless a niche market manufacturer can apply economy of scale ,its a good idea to be sure you can get all the way there before you get halfway there.
There are only so many transmissions.
Titanium nitride may have some small potential.kamiphloj
Heat treating gears
Re: Heat treating gears
Great line !kamiphloj wrote:Unless you have a great deal of resources (Powerball)...
And Thanks for the information as well.
