Hello all,
Here are photos of my recently purchased 1984 Tercel SR5 4x4 wagon. This is my second Toyota, my first was a 65 Crown Deluxe. Anyhoo, I was searching for a light 4x4 to take offroad. Being a believer in lighter rather bigger 4x4's I looked at all the usuals, Suzuki Sierra etc.
Browsing my local Marketplace I found this Tercel. I looked at all the specs and thought it sounded good on paper ( if you exclude all of the reports about the slowness of the car, its poor carburetor or its tendency to do valve seals etc.)
I went and checked it out and purchased it on the spot. It doesn't blow any smoke and the motor seems really nice. I'm just going through fixing the items that it needed to pass Roadworthy.
Here is a very short video of the drive home from purchasing https://youtu.be/gkntqYWAJLY?si=bHQ4S9b6-xpCZe-t
I had to fix:
Rear pass brake cylinder
Water temp sensor
Centre Driveshaft bearing
Rear water nozzle blocked -free
Heater control ? This is still a problem - I have made a seperate post in the technical section on this.
Front swaybar mount rubbers
So far I have found all of the parts that I need locally at Repco etc and at ridiculously low prices. I paid $10 for wheel cylinders, and $80 for the driveshaft bearing. There seems to be a truckload of these old parts sitting around on shelves here.
I have also found that there are local eBay sellers advertising ventilated, tercel disks. https://www.ebay.com.au/itm/40422652412 ... BMxpyiv75j This will be done asap.
I am also planning on a lift kit. After that I will be hitting the trails!
New member and more importantly car in Australia
- My tercel:: 1984 SR5
Re: New member and more importantly car in Australia
Welcome to the forum, CrownDeluxe! I hope you get around to posting pics of your car, the Aussie models always seemed to have more cool options than the North American models did.
Welcome CD,
While the pic shows vented rotors, they indicate “solid” in the literature. If you want vented rotors, you can step up to the MR2 rotor/caliper swap.
