Free: Parts Collection, GONE to a true gentleman
mrdance123
My tercel:: 84 and 85 4wd wagons
Post by mrdance123 »
So this was all picked up today July 29th........
I'm cleaning out all my Tercel stuff, bring a pickup and take it all away!! FREE
Portland Oregon.
SCROLL down a bit, to see the pictures I finally posted, continue to page 3......
Transmission, 4.1 transaxle and rear differential.
source: pulled from a blown engine 85 tercel
Left front fender spotless no rust.
Hatchback lid spotless
Large collection of RockAuto purchased parts
seals gaskets for almost everything engine transmission,
wheel bearings, brake rebuild kits
Almost everything removable I have it, from completely parting out 2 Tercel 4x4's
Except, there are no seats.
Side mirrors both sides
Multiple sets of window regulators including driver's, window glasses all around.
Salvaged window and door seals, descent shape
Sway bar, front spindles, power steering rack assembly,
including all the hydraulic lines and steering pump.
Front axles some with unbroken boots.
AC parts under dash evaporator and under hood condenser,
(no compressor, sorry)
driving computers above glove box,
AC controllers, blower fan, + good fan speed resistors !!!!
several speedometer panels, some with the tachometer
several turn signal stocks,
wiring harnesses all around
perfect intact complete climate control panel with all cables
taillight lens pullouts, front grills and headlights,
and most of an '87 upgraded headlight set and grill
Starters, alternators, a dozen stock carbeurators, an handful of them run fine.
a dozen or more of the temperature sensing vacuum valve trees on the intake manifold,
much more too many to list them all
Re: Free: Transmission, vast parts collection
So you’re gettin’ out of the Tercel or just cleaning up? Incredible offer for somebody reasonably close.
MrWrench
Post by MrWrench »
Aw man, If you weren't 2500 miles away, I would gladly find good homes for all these parts.
Very generous offer and I really hope these parts find a good home!
SirFoxx
Post by SirFoxx »
mrdance123 wrote: Thu Jul 13, 2023 4:17 pm I'm cleaning out all my Tercel stuff, bring a pickup and take it all away!! FREE
Portland Oregon.
I'm ready to haul it all to dump.
and compressor that may be rebuildable?
would i be able to get my hands on some of the tvsv and stock carbs? maybe any carb rebuild kits if you have any?
1985 4wd Tercel SR5 (RIP)
mrdance123
I am looking for someone to take all for free (need a pickup or van)
Connee1979
My tercel:: 1985 Toyota Tercel wagon sr5
Post by Connee1979 »
I am up in the Tacoma area and would be interested in picking this up
Herbou
My tercel:: 1983 Wagon
Post by Herbou »
Hi,
Would you be willing to throw the power steering pump, hydraulic lines and tensioner bracket into a USPS box and post to 75032? I am happy to purchase the items from you.
Thank you
mrdance123
PM me if you are interested please.
I hope someone wants to come and take everything for free,
with a pickup or trailer, and I can be done with it.
Make me a cash offer on specific parts, PM me
in person pickup (no mail) at Beaverton Oregon area code 97007
SirFoxx
Post by SirFoxx »
mrdance123 wrote: Fri Jul 14, 2023 5:01 pm I am looking for someone to take all for free (need a pickup or van)
Otherwise, a running stock carb is $200,
after a driving demonstration, I will remove it on the spot to sell.
it will idle smoothly and go into full secondary power.
Collection of 12 TVSV's and a gas valve all for $50, none are tested.
I always pulled these when discovered at the pick n pull.
200 for a stock carb? GLWS.
Joe9740283sr5
My tercel:: 1983 Toyota Tercel SR5, stock
Post by Joe9740283sr5 »
I will come get all the parts if they're still available. I can be there tomorrow.
Hines11b3x
My tercel:: 85 SR5 4WD Jeep coils, air shocks, weber carb
Post by Hines11b3x »
Do you still have everything? I’m in Salem and can come up there and get it.
mrdance123
From an '84 4wd with blown engine
front differential, clutch housing
flip side of front differential
Transmission
REAR differential, Front axles, spindles, struts
Drive lines
mrdance123
Box 4
2 EBCV’s, one with it’s bracket and relays
2 EGR valves
Dome lights, side markers,
Relays under dash behind kickpanels and from fuse box
3 Computer boxes from above glovebox
2 ac control modules
Under hood cables
Random harnesses, and main firewall grommet
Box 1
Sun visors, firm!! not puffy
Set belt set
Tail lights
Air inlet leaf filters ?
BOX 5
2 climate fans in housings,
Associated relays in baggie,
charcoal canister
FAN SPEED RESISTORS
If your fan is missing some of it's lower speeds, this is the culprit
It’s not the fan, it’s these coiled up resistor wires burned out like a light bulb.
They are under glovebox inserted into the main incoming air duct
where they are cooled by the airflow.
mrdance123
Window regulators all 4 doors, not stipped out
Battery tie downs, decent
both front door 'hinge' 'springs?' they slow hold the door from flopping
front windshield wiper pivit and push rods (under hood vent cover)
Keysets
GLASS
2 sets, both front doors
1 set, both rear door windows
1 set, rear side glass
Mirrors, various condition, both sides
mrdance123
'87 upgraded lights, no longer sealed beam
can be put in '83 to '86 with new grill, included, photo somewhere below
mounting brackets, and partially intact trim
obviously 'newish' steering tie rod end found on T4 at the pick n pull
standard set '83-'86 light mount brackets and trim
orange side markers,
2 earlier model grills
1 '87 grill for headlight update
A/C evaporator, under dash
radiator
