Blown head gasket scenarios/ diagnosis
I swear I smell water in my exhaust and I think I see it coming out of my oil cap when I open the oil cap with the motor running but I really do not have intrusion into my oil so it’s super trippy just trying to figure out the best way to diagnose..
I tested the coolant with the blue liquid stuff and no color change-o
Re: Blown head gasket scenarios/ diagnosis
When I'm trying to diagnose a bad head gasket, these are the key things I look for:
- running poorly, but in an odd or inconsistent way
- consuming coolant (I check the overflow reservoir each morning before I start the car)
- low compression test results on two adjacent cylinders
There are other things people look for, like chocolate milk-ish residue on the underside of the oil cap, and bubbles in the coolant if you take the rad cap off, but the three things I listed first have worked reliably for me. Plus I had an air-cooled VW Vanagon and it perpetually had chocolate milk on the underside of the oil cap so I've never felt that one was a very reliable method.
BL8,
How is the car running/driving? I tend to look for coolant in my oil. Small amounts show up as whitish and/or light brown specks on the dipstick. I have some blow-by (though the car is running well) and if I remove the oil filler cap with the engine running, it will spit some at me, but it’s just oil. If really concerned, the compression test is the way to go.
David - the underside if the cap isn’t a bad spot to check. I would suspect the air-cooled engine experienced “interior” condensation causing what you saw.
I agree, there must have been some moisture in there somehow but it made me wonder, if there was moisture even in my air-cooled engine, couldn't the same happen to a regular engine? And I've seen similar on my cars which have definitely not had bad head gaskets, so it just hasn't seemed like a reliable diagnostic for me. Not saying it can't work, just not one of my go-to's.
I wondered if it may be more common with air cooled engines? I’ve not seen it on water cooled engines hardly ever, unless there was an issue.
NWMO wrote: ↑Wed May 17, 2023 8:59 am BL8,
It runs great..
I cant for the life of me find water in my oil…
But I definitely have some white smoke and a strange stink to my exhaust..
I guess compression test is the call?
Recommended tester? To buy
- SirFoxx
on these cars, coolant in oil failure mode is very rare in my experience.BL8R29 wrote: ↑Tue May 16, 2023 11:17 pm I swear I smell water in my exhaust and I think I see it coming out of my oil cap when I open the oil cap with the motor running but I really do not have intrusion into my oil so it’s super trippy just trying to figure out the best way to diagnose..
dont be looking for a problem if there is not one. if you dont have exhaust gas leaking into the radiator, and your coolant level isnt going down consistently, then your head gasket is fine. its normal for a minor amount of steam to come out of the exhaust due to condensation. the engine would have to be drinking more coolant than gas for it to be noticeable in the exhaust.
also water doesnt have a smell, so im not sure what youre smelling coming out of the oil cap. probably aerated oil. and smelling it is not the right way to check. the thing to look for is an excessive amount of milky oil on the cap. However, even then, thats not a good indicator as its normal for condensation to form in the engine, and to get mixed around a bit before evaporating.
I personally like using the tester that you have to physically hold on the spark plug hole vs the screw in ones. the cheapo screw in ones have screw on adapters for the different thread pitches, and they always get stuck in the head when trying to unscrew them
make sure to unplug the dizzy and hold the throttle wide open when doing the compression check.
1985 4wd Tercel SR5 (RIP)
Here's a link to an affordable compression tester I purchased on ebay:
https://www.ebay.com/itm/281352084227
I bought it because my HF tester started giving misleading readings. There is a lightweight schrader valve on most testers that acts as a checkvalve... if it leaks you'll get false low readings.
If you still have the catalytic converter, strange stink and moisture are somewhat normal. This might be more likely if you have run the car for short trips, where the exhaust system hasn't heated enough to cook off all the accumulated moisture.
You can pull the plugs and look for signs. Shine a light into the spark plug hole and looks at the piston tops. An unusual clean looking cylinder might be an indicator.
+1SirFoxx wrote: ↑Thu May 18, 2023 6:33 am
Thanks! To clarify the strange smell and white smoke im smelling is from the exhaust..SirFoxx wrote: ↑Thu May 18, 2023 6:33 amon these cars, coolant in oil failure mode is very rare in my experience.BL8R29 wrote: ↑Tue May 16, 2023 11:17 pm I swear I smell water in my exhaust and I think I see it coming out of my oil cap when I open the oil cap with the motor running but I really do not have intrusion into my oil so it’s super trippy just trying to figure out the best way to diagnose..
Any idea the name of / brand of the nonthreaded compression test?
- SirFoxx
does it smoke cold, warm, all the time, first start up...?
are you running water or antifreeze?
ive got this one.
https://www.harborfreight.com/compressi ... byEALw_wcB
SirFoxx wrote: ↑Thu May 18, 2023 8:25 amdoes it smoke cold, warm, all the time, first start up...?
ive got this one.
On startup definitely…
Sometimes randomly more than other times while driving
Green antifreeze
- SirFoxx
are you losing coolant?
Make sure to always check your coolant level at the overflow reservoir, when the engine is stone cold. I find this is the easiest way to track if there is any coolant loss.
