Has anyone recently purchased new input shaft (particarly the inner that if worn can cause noise when clutch pedal is up), main shaft, or other commonly worn-out bearings (still figuring that out, read a lot but comprehended less) for the transmission?
I plan to try calling Locate Ball Bearings when they are open but wanted to know if someone has had success recently at all.
Transmission bearings
Re: Transmission bearings
Sorry for the late reply, but Robert has a great list. It may be linked under the “short cuts”. If not, I need to add it. Locate BB is who I used and most are still available.
Thanks. I don't know if I inadvertently changed the settings for my account as I didn't see a reply notification and I am just seeing your message now. I have seen a list Robert has in Transmission Repair Notes, the last update date I saw was from a bit ago so I wasn't sure by now. I guess I will stick with my plan and check with Locate BB.
- My tercel:: 1986 Toyota Tercel Wagon
I had my Trans torn down A while back,due to a God awful Grinding Sounds while the Trans was in gauged...The Main Bearings on the Main Shaft were bad...
