Carb auxiliary pump vacuum line full of fuel, why?
- My tercel:: 1985 Toyota Tercel 4wd Sr5, Fed emission but no cat converter. Manual transmission, with air conditioning.
I just tried to overhaul my carburetor and found no obvious issues besides the vacuum line going to the auxiliary pump was full of fuel. I've been away from mechanical things for a while and cannot figure this out. Anyone had this problem? What do we do to take care of it besides capping it off?
Re: Carb auxiliary pump vacuum line full of fuel, why?
Ruptured AAP diaph- part of the carb rebuild kit (happens all the time.)
Thanks rer233, what should I be on the look out for after this happened?
No harm from a ruptured AAP, it just means the manifold has been sucking extra fuel and causing the engine to run rich. Like Rich said, if you bought a carb rebuild kit there should be a new AAP in there. If not, just cap it and the hose that went to it until you can replace it. The AAP supplies extra fuel while the engine is warming up, not a huge deal if it's disabled.
- garyfish
Rock Auto carries the AAP diaphragm for $11.69 each, plus shipping. It's for 1984-88 Corollas but a Forum user has posted that they also fit our T4WD's:
viewtopic.php?t=14083
