B25-145 Bearing Cross
Yaut
My tercel:: 1985 Toyota Tercel 4WD automatic, lifted 1.5", 15 inch wheels
Post by Yaut »
Does anyone know if the 25BC06S47Z NACHI bearing is a suitable replacement for the B25-145 NSK? I am having trouble finding cross reference information. I believe the original B25-145 bearing specs are 25mm x 63mm x 17.5mm
Re: B25-145 Bearing Cross
Diarmait,
The 25x63x17.5 is for the rear bearing on the input shaft correct?
https://www.ebay.com/itm/Genuine-Toyota ... %7Ciid%3A1
If you are after the rear input shaft bearing, it needs the snap ring, which I'm not seeing on the NACHI (though the size looks correct).
Yaut
Post by Yaut »
Chris,
Yes. For the rear of the input shaft and the front of the main shaft also I believe. Thanks for the link! I'll pick it up. I also got my Koyo bearings for the front of the input shaft from Locate Ball bearings thanks to you.
Diarmait,
I look forward to wrenching with you, Keegan and Satchel sometime, maybe on a group “Gambler” Tercel! Could be a campfire 🔥 conversation at the Meet & Greet!
Yaut
Post by Yaut »
Chris,
I have a good canidate for a "Gambler". At least if I can figure out how to get a title. Getting excited for the meet up. Coming up quick!
