Help me troubleshoot a short circuit in my Previa van, please!
Came in to drive van in the morning: garage smells terrible. Drive van, van smells like burning plastic. Initially wrote it off as leaky oil burning (I haven't gotten around to fixing my valve cover gasket). Get into van after letting it sit with windows open, still smells. Notice my clock and radio no longer work. Electrical short! Clock fuse is blown. Radio fuse is not blown.
My question: What circuits are likely to be "always on" in a '95 Previa?
-radio
-clock
-power door locks
I disconnected the battery and I'm hoping that if I pull all the possible fuses I can avert further damage. In the morning I will check for all the fuses which have power while the ignition is off. Don't have much time to troubleshoot or repair, though. I'm 6 hrs away from home right now and need to get back from holiday travel by school on Monday!
Thanks!
I Smell Burning: Short circuit overnight
- tallsailor
- My tercel:: '83 4x4 w/blue plaid
'83 Tercel 4x4 blue plaid interior
'95 Previa SC AWD rally machine dadvan
Sadly deceased: '95 Tacoma 2.7l 4x4
Re: I Smell Burning: Short circuit overnight
TS - you might have better luck over at Toyotavantech.com
Theres even a Previa specific section, good group over there, almost as good as here
- Mattel
power locks? what sort of wizzardry is that?
although to note is that the Australian SR5 wagons do have a remote control lever for unlocking the rear door down near the petrol flap lever infront of the passenger seat.
Hopefully you got sorted out but in case you didn't, there is supposed to be a fusible link box on the positive post of the battery, they are known for causing grief similar to what you stated. Not enough to take the top off and look, many have had fried innards and only visible from the underside.
- tallsailor
I think the auxiliary rear heater blower motor supply burned, but I haven't been able to tear apart the dash and A pillar to confirm. I pulled fuses until the awful smell went away and managed to drive home. I'll try toyotavantech.com; I've lurked there, don't know why I didn't just make an account.
in most cars the headlights will come on with the ignition off, so the headlight system is always energized. Most of the newer cars have an auto off feature on the headlights, too many people forget to turn the headlights off and allow the battery to run down.
