Hi,
So I am having a weird issue where if I am not driving or revving the engine the temp shoots way up. I think that it is related to the battery and how much juice it is outputting (I clued in that this might be the issue when I noticed the lights dim when I got to a stop). Would this be a battery issue or an alternator issue? I looked at the battery and there is some corrosion on the terminals but would that reduce the effectiveness of the battery? Just time for a new battery then?
Thanks
S
Tercel overheating when I DON'T rev the engine
Driver: '86 4wd Tercel Wagon
Fun: '98 BMW M3 sedan
Now I have the best of both worlds!
Re: Tercel overheating when I DON'T rev the engine
Or after doing some searching, could be the water pump or the rad hose. I will check those when i get home
that is not related to the battery, it is normal for lights to go dim at idle since the alternator is usually below the batter voltage. if the lights go bright when you rev the engine, it means the alternator is working correctly.
It is not likely related to running the engine slow, it is more likely that you are stopped and no air is flowing through the radiator. check the function of the radiator fan, and the fan switch or sensor (it is at the bottom of the radiator next to the lower rad hose).
try this: when you are at a stand still and the temp starts to rise, turn on the heater fan with temp selector to hot/high. if the temp comes down, you have limited cooling capacity. Either rad fan not coming on, or radiator is not cooling the engine due to built up inside of it.
good luck.
good luck.
One more thing, and possibly/probably unrelated, but you might as well check -
viewtopic.php?f=7&t=6915&hilit=leaves
For that matter, while Goldie's previous life was outside Nashville, youse guys in the PacNWST seem to be subject to trees weeping all sorts of detritus.
